Question about Initial DTV-171 17 in. TV/DVD Combo
How do I get sounds when I use the red green blue rca hook ups?
    President:
  • 624 Answers
The red, blue and green RCA hook up is just video. You must also use the red and white pair of RCA jacks for the audio. You can usually find the audio red and white jacks right below the video red, blue and green RCA jacks. Get yourself an audio RCA cord with the red and white connectors and run that from your video device audio output to the audio input of the TV that corresponds with the video input of the TV. An example would be if the red, blue and green are on the "Video 1" input of your TV you will find the red and white audio input for "Video 1" right below or right next to the video inputs.
The red, blue and green video jacks are called "component video" and they only have a video signal for high definition video, so you must also run a separate audio line for it. The same holds true for the yellow video RCA connector, that one is called "composite video" and it also has only a video signal with no audio.
I hope this helps, if so a "FixYa!" rating would be very much appreciated.
If you need more help just post your concerns right here onthis thread.
Dave
Posted on Nov 28, 2008
I hooked up my cable box up to my sceptre tv and it had sounds but the picture is black and white I even went and bought the blue and green cords but still only black and white
With the blue/green/red cords (Component) you need to get a very good bright light on the connectors so you get the plugged into the correct COMPONENT connectors on the TV. Note, there are white and red AUDIO plugs right near the COMPONENT input so you need to be VERY careful. If you get it wrong, the colors on screen are often off and even black&white.
How is your cable box connected to the TV? Screw on "COAXIAL", Yellow, Red, White "RCA", single flat connector "HDMI" or 5 colored plugs 2 X Red, 1 X White, 1 X Blue, 1 X Green "COMPONENT"
Jan 08, 2014 | Televison & Video
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
How to hook up xbox 360 to jvc dlp thru hdmi ports
You can use an HDMI-to-DVI cable for the TV's DVI input and this would give you video at full HD 1080p resolution but you need to route the audio via standard red & white RCA. It would be better if it has digital audio inputs such as optical or coaxial to get Dolby Digital and other digital formats from your source.
If in the unlikely scenario that it does not have a DVI input (which looks similar to your PC's blue VGA only wider and is white) you can hook it up to your component video-in (which is the red/blue/green RCA inputs). For this you need a cable that has HDMI on one end and red/blue/green for video RCA's +red/white RCA's audio.
This would give you 1080i resolution with stereo audio.
Hope that helps.
Aug 27, 2009 | JVC Televison & Video
Sharp tv that sound doesnt work using rca cables the red green and blue wires
do you have sound if you hook up cable to the tuner if so check your wire.
Aug 19, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
DVD won't play movies in color
RCA cable connectors (red,white, yellow) are usually for an analog setup. You could still use these for "component" setup, but know the difference with color stamps as follows:
Component color stamps are "blue, green, red" ( blue is marked Pb, green is marked Y, red is marked Pr)
RCA color stamps your using are "red, white, yellow"
Here are the proper hook up method for "Component" using your "RCA" connectors:
On both the TV and DVD component setup:
Plug the red RCA fitting in the component port marked "Pr (red)
Plug the white RCA fitting in the component port marked "Pb (blue)
Plug the yellow RCA fitting in the component port marked "Y (green)
Be sure this setup is the same for the TV's component input ports, and the DVD's component output ports.
i-Note:
For optimum picture quality you may want to purchase component cables as the gage is thicker giving better impedance match resulting in better picture and sound quality.
Jan 25, 2009 | Vizio Televison & Video
Sound on my emerson dvd player
YOU MAY HAVE HAD A CHANEL GO OUT,, OR CHECK THE MENU ,,IT COULD OF BEEN PUT ON DIGITAL INSTEAD OF ANALOG,,,,,UNLESS YOUVE HOOKED IT UP WITH COMPONENT JACKS ,,RED,GREEN ,BLUE ,,JACKS ,,IF THATS THE CASE ,,THATS FOR VIDEO ONLY,,HOOK UP SOME RCA JACKS WITH IT IN THE RED AND WHITE AUDIO JACKS,,,GOOD LUCK
Sep 04, 2008 | Emerson EWD2204 DVD Player/VCR
Have sound,no picture
Do you have it hooked up using the component cables?(red, blue, green cables?) You need to use the component cables to use the progressive scan feature. So if you have it hooked up using the yellow rca jack, you will have to switch cables.
May 30, 2008 | GoVideo Go Video DVD/VCR Combo
Initial DTV-171 17 in. TV/DVD Combo Logo
115 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
