Acer Aspire 5000 - DVD ROM problem
Sir, I am having Acer 5000 Laptop. When I place any CD / DVD in the DVD ROM, only the light flickers without any action. I have enquired about this to my friend and he said that if the lens were dislocated, then this sort of problem may arise and added that he doesn't know the solution for this. Can you please help me.
Warm regards
Jagadeesan
  • 2 more comments
  • gjagadeshan9 Nov 29, 2008
    As you said, no program is accessing the cd rom. instead, it wont identifying any cd or dvd.
    Yes Sir. I tried it. Even though, the device is not sensing any cd or dvd. Can we change the lens only ??? is it possible ??
    Sorry for troubling you very often. Thank you for your immediate response.
    Can you please tell me how much it costs ??
    Thank you so much Sir.
    with warm regards
    G. Jagadeesan
    President:
  • 2,110 Answers
Is there any program running in background that access the cd rom..if yes try to close that one by pressing ctrl+Alt+Del
Posted on Nov 29, 2008
  • 1 more comment
  • Sibananda Jena
    Sibananda Jena Nov 29, 2008
    OK,Then it seems to be some problem with ur lens..try to use a lens cleaner for cleaning lens...
  • Sibananda Jena
    Yes it can be done But you can't do by urself..So u have to take it to nearest service center...
  • Sibananda Jena
    I dont have much idea about LAPTOP dvd rom...But for desktop it will cost around 600-700 INR
Removing cd rom
The optical (CD) drive on your Acer laptop connects to the side of the device and is accessed via the underside of the computer.
If you are having problems with the optical drive on your laptop you should address it as soon as possible, and one thing you may need to do is remove it.
The good news is that even if you aren't particularly tech savvy, you'll find that the process of removing and replacing your optical drive is relatively easy.
Turn your Acer off and remove any power cables that may be attached to the side of the unit. Turn your Acer upside down.
Slide the battery out of its compartment on the underside of the computer.
Locate the circular optical drive retaining screw on the underside of your laptop.
It is located just above the square WiFi compartment in the middle of the computer.
Use your Phillips screwdriver to remove the screw and set it aside.
Grip the optical drive by its edge on the side of the computer and gently pull to remove it from the computer.
Slide a new optical drive into the computer, making sure the disk opening is facing out of the laptop.
Replace the optical drive screw.
http://doube.org/aspireoptical
http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
Replace the CD Drive on an Acer Aspire 5000
The CD drive of the Acer Aspire 5000 is designed like most other laptop optical drives.
The CD drive is on the right-hand side of the computer and is attached with screws from the back of the case.
All you need to complete the task is a screwdriver.
To avoid electric shock or damage to the laptop, always ground your tools by touching them against a metal object like a table leg before using them on the computer.
Turn the Acer Aspire 5000 laptop off.
Unplug the power cord from the electrical outlet. Remove the power cord from the power supply in the side of the laptop.
Flip the laptop over so you are looking at the bottom of the case.
Slide the battery pack off the top of the case.
You'll see the CD drive on the left-hand side of the laptop when you are looking at the bottom of the case.
Unfasten the screws that are holding the CD drive onto the laptop with a screwdriver. Slide the drive out of the case.
Slide the new CD drive into the case and secure it with the screws.
Place the battery pack in the laptop and turn the computer back over so it is sitting on its base. Plug the power cord into the power supply in the side of the laptop.
Plug the other end of the cord into the electrical outlet.
http://www.batterystyle.com/acer-aspire-5000-drive-p-307461.html
Sep 06, 2013 | Acer Aspire 5610-4648 Notebook
Tip
Acer Aspire Netbook without external DVD/CD rom How to Load CD
This will work on any model or make of net-book or Laptop enabling you to load CD's or DVD s with software onto your net-book laptop especially good when the CD/DVD drive has stopped working or is non existent, there are a few prerequisites before you can carry out this operation.
1:You must be in a networked environment in your home/workplace
2;One of the networked computers must have a CD/DVD ROM available
3:The computers must have been linked in a home or a small office network
4: Printers and sharing must also be activated in that network
Method is as follows:-
On the Work-group/Home network computer with CD/DVD ROM click on Start then my computer and look for CD/DVD ROM icon.
Right click on the icon then click sharing and security enable sharing and security then restart this workstation , You will then see the shared hand icon underneath this icon representing it is a shared item after restart to confirm it is shared.
On the laptop/net-book look in my network places you will see the CD/DVD ROM available to you now all you need to do is place in the work-group computers CD/DVD ROM the required software disk and there you have your problem solved without the expense of purchasing an external CD ROM
Operate now your Net-book/Laptop with available CD/DVD icon and double click it or right click and explore choice is yours.
Look at following Pictures
I hope this explains how to do it if you have further problems let me know
Should you not have at least the above 4 listed items at the top of the page then this method wont work .I will publish another method soon for those people that have no network and only have a single net-book/Laptop with no CD capability
on Feb 28, 2011 | Computers & Internet
How to remove cd/dvd drive on a acer aspire 5003WMLi
Turn the laptop over, on the bottom you will find a screw about 5-6 inches in from the cd-rom drive. The screw will have a little symbol of a CD next to it. If you remove this screw the cd-rom drive should slide right out. Be sure to do this with the laptop turned off, unplugged and with the battery removed.
Sep 19, 2012 | Acer Aspire 5002 Wlci Zl5 - 5000 Series...
Acer aspire 5315
well i think you are asking for to use your dell cd to install in your sister's laptop.maybe it will not work because they are specific system configured .you can't use them everywhere.
Mar 31, 2010 | Acer Aspire 5315 Notebook
Laptop will not switch off untill press switch button of laptop
you have a corrupted software try to format and reinstall it again, most corrupted system comes from improper shut down sometimes during installation your CD or DVD rom is defective although it is reading and seams working fine try to install your system using other rom drive
Sep 18, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire 5000
The driver for the cd rom is built into windows. If the cd rom is saying all cd loaded are blank then you have a damaged cd room. You will need to buy a cd rom lens cleaner to make sure the lens is clear of dust
Jan 26, 2009 | Acer Aspire 5000 Notebook
Acer Aspire 5000 CD Drive Problem
hi!,
1.this is not a problem of your operating system.so don't format again.
2.you must install the drivers for the CD rom.
3.if not fix it is a problem in the circuit board of CD rom,very difficult to fix.
thanks
Mar 01, 2008 | Acer (91.AB264.023) Internal 32x CD-ROM...
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
283 people viewed this question
Alun Cox
David Payne
David Payne
