Question about Linksys WPSM54G Print Server
Cant find print server to configure the IP on our network
  • pcfixer0911 Mar 02, 2009
    Trying to connect the WPSM54G Print Server to an HPC4480 All In One Printer, Scanner, Copier. It keeps asking for the password that I don't have.
    Problem Solver:
  • 9 Answers
You can change the IP to ur print Server
or u can type
ipconfg in cmd
and u find the IP
in print server
or send the type off machine and i tell u how u can change the IP for the printer
Posted on Nov 29, 2008
2 Suggested Answers
SOURCE: I have instatalled a DP 301 print server for my HP
Yes. In most cases you can reset your D-link DP-300 series or DP-301 series print server yourself even if you don't know the password or IP. This comes in handy in situations such as when the server has made up its own password after being connected to a new router.
Cross your fingers and try the following steps...
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
5) Follow the non-intuitive instructions provided with your server to set it up again. (Note that a Quick Install Guide will likely be more useful than a manual for this step. If you have lost your Quick Install Guide then try downloading it from D-link's website, http:/www.dlink.com/default.aspx Locate your model via "product quick find" or "find your product" then click on "support resources" and look for a quick installation guide.)
Shahzad IT Department Mitsubishi Motors KSA
Posted on Jan 17, 2010
HPlaserjet 2600n without IP
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Apr 16, 2013 | HP Color LaserJet 2600n Printer
Set up wirelessprinter hp
Jan 28, 2013 | Office Equipment & Supplies
Wireless printer configura
These instructions generally apply to all networkprinters with built-in network cards (print servers) such as HP LaserJetprinters, IBM Infoprint laser printers etc.This example is for a network HP LaserJet printer.To install a HP printer (with built-in Jetdirect printserver) as a network printer you need to do the following -
1. Open the printer's menu and enablethe Network Card - these print servers use a static IP address therefore,configure the IP address of the network card so it matches the IP range of yournetwork. Eg. If your IP's are 192.168.0.*** then set the network card to a highnumber say 100. (This is to prevent a conflict with the router issuing the sameIP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IPaddress range that the router issues to the computers on your network andconfigure the static IP address in the printer's network configurationaccordingly.
2. Install the HP printer driver onyour computer/s using the LPT printer port.
3. Connect the printer with a LAN cableto the network hub/router.
4. Click on Printers and Faxes - rightclick on the HP printer and click on Properties.
5. Click on Ports and click on AddPort.
6. In available ports - click onStandard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IPaddress of the HP's printer IP address.
8. Click OK and tick Enablebi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printerprints correctly.
Install the HP printer driver on every computer on your network and configurethe printer's TCP/IP port as previously detailed.Do a test print page to check the printer.
Jul 31, 2012 | HP Office Equipment & Supplies
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
I need to get a wpa passphrase how do i get 1
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
Need to install network printer to DLink Router
It has been a few months, so you probably have resolved this -- but just in case someone else is looking to find out the IP address on the internal print server of an HP Laserjet 4000n printer so they can set it up on their network, here are the steps to find the IP address on the HP JetDirect internal print server:
1. Have the Ethernet cable plugged in to the router and the JetDirect 600n card and power it on.
2. Make sure display screen on printer says "Ready".
3. Press the Menu button on the printer until you see Information Menu.
4, Press the Item button on the right (+) side until you see Print Configuration page.
5. Press the Select button and a configuration page should print.
One page is the printer's configuration and the other page is the print server configuration page. If you have a good JetDirect card, and good connection to your router, the IP address of the printer, plus its subnet mask and default gateway should be shown on the EIO configuration page.
If the printer has been manually set with a static IP address, subnet mask and default gateway that will not work on your network, you will see the settings will indicate "Configured by" User Specified.
To clear those settings and allow DHCP setting, perform a cold reset on the JetDirect card, by powering off the printer, holding down the green "Go" button and powering it back on until you see "COLD RESET," let go of the green Go button, wait a couple of minutes, then run another configuration page to see the freshly assigned DHCP address of the print server.
Hope this helps someone.
Mar 14, 2009 | HP JetDirect 600N Print Server
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
My brother printer MFC-640CW has stopped taking comand to print documents from my computer, i can copy and scan, but not print . ink pads are full.
Make sure the status and configuration of the print server. Check following:
1 Make sure that the machine is powered on, is on-line and ready to print.
2 Print the Network Configuration List of the machine and check if the settings such as IP address settings
are correct for your network. The problem may be the result of mismatched or duplicate IP address.
Verify that the IP address is correctly loaded into the print server. And make sure that no other nodes on
the network have this IP address.
3 Verify that the print server is on your network as follows:
For Windows®
(1) Try pinging the print server from the host operating system command prompt with the command:
ping ipaddress
Where ipaddress is the print server IP address (note that in some instances it can take up to two
minutes for the print server to load its IP address after setting the IP address).
(2) If a successful response is received, then proceed to Windows® 98/98SE/Me Peer-to-Peer print
(LPR) troubleshooting
. Otherwise, proceed to Step 4.
4 Reset the print server back to the default factory settings and try from the initial setup again. For
information how to reset to the default factory settings, see Restoring the network settings to factory in the manual.
Jul 01, 2008 | Brother Office Equipment & Supplies
Cant find the Print Server IP
when you tried to ping the restored ip for the print server did your computer was in the same subnet? if not try to configure your machine ip to be in the same subnet for your print server ip.
Jun 14, 2007 | Hawking HWPS1UG Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Linksys WPSM54G Print Server Logo
232 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
