Question about Nintendo Wii Console
The power was out and now tteh console don´t turn on. How can access to the fuse
  • 218 Answers
Try unplugging the power adapter for at least 90 seconds. Make sure that the power adapter is plugged into a live outlet. If it's plugged into a power strip or uninterruptible power supply, check to see if there's a reset button on that. Here's a link to the manufacturer's web page about power problems. Good luck.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Posted on Nov 28, 2008
The link solved my problem in 2 minutes....thanks
Posted on Mar 17, 2010
Where and witch fuse is for power window, 2004 Buick rendezous
All of the power windows don't work ? There isn't a fuse , a circuit breaker powers the windows !
PWR WDWS CIRCUIT BREAKER #35 30amp. located in the fuse block center console .
Fuse Block - Center Console
Inside of console, behind the right console access panel
Sep 04, 2016 | 2004 Buick Rendezvous
2003 Buick rendezvous turn signal, and brake lights, and hazards lights stop working
Check the HZDLFL fuse# 40 - 15amp in the console fuse block
Inside of console, behind the right console access panel , if the fuse is good the turn signal / hazard flasher module is bad.
Turn Signal/Multifunction Flasher Module
In the fuse block - center console
Dec 05, 2015 | Buick Cars & Trucks
Where is the power window fuse located, and what number is it
Instrument Panel Fuse Block
The instrument panel fuse block is located on the passenger side of the vehicle, on the lower portion of the instrument panel console near the floor.
Remove the console cover to access the fuse block, then remove the fuse block cover to access the fuses.
http://www.vadengmpp.com/owners-manual/pontiac/2008-Pontiac-G6.pdf
May 26, 2015 | 2008 Pontiac G6 Sedan
I need to know what fuse is for the power side mirrors for a pontiac aztek
Without knowing the year of your Aztek, I can only take a stab with what I know about the 2001.
This vehicle has two fuse & relay centers, the first one is located in the engine compartment, on top of the windshield washer fluid reservoir (you don't want this one for the problem you described).
The second one is located inside the passenger area of the vehicle, behind the center console, to the right of the gear shift lever.
Locate the removable access panel and give it a good yank to expose the fuse panel.
3_27_2012_7_05_49_pm.gifNow locate and check the fuses in slots # 16 and 17 (one of these should be your culprit).
After you have replaced the fuse (with a fuse of the same amperage) place the access panel onto the opening and give it a whack with the **** of you fist or a rubber mallet.
I hope this helps,Danno
Mar 27, 2012 | 2003 Pontiac Aztek
I have no brake lights in my '97 dodge caravan le but i have taillights
Have yoiu changed/checled the lightbulbs? (In other words,do your turn signal lights work? If the front turn signal lights work, but the rear don't, then turn on your four (4) way flashers. If the rear lights still don't work, then all the bulbs are bad. It is rare for all the bulbs to be burnt out at the same time, but it does happen.
If the turn signal/four way flasher lights work, then you probably have a bad brake light switch. However, first check your owner's manual to make certain there is not a separate fuse for these lights. If there is, then swap the fuse for the brake lights for another fuse (or relay) of the same size/amperage. (Facing the hood, the power relay box is located on the right side (usually) under the hood.)
The fuse box is located under the dash, on the driver's side of the car. Usually there is a plastic cover that has to be removed to access the underside of the dash, and then there is a plastic cover that has to be removed to access the fuse box. If you don't have an owner's manual, nprmally the fuses and power relays are normally marked on the plastic covers your remove ot access the fuses and power relays.
If the fuses/relays are good, then you have a bad brake light switch. This is located on a bracket just above the brake pedal. When you push the pedal down, the switch makes contact. Disconnect the plug to the switch, and jump across the plug contacts (not the switch) with a small piece of wire, or if a piece of insulated wire is unavailable, you can use a paperclip, you won't get schocked, just make certain that the paperclip does not come in contact with a ground while you have it plugged in to the plug for the brake light switch.
If the lights stil dont work, check for power to the plug for the brake light switch. If you have power to the plug, the turn signals and four-way flashers work, then my guess would be that you have a broken power wire (probably iside the steering column, or a bad turn signal switch. If the brake lights work whe nyou jump out the brake light switch, then the brake light switch is defective.
Oct 16, 2011 | 1997 Dodge Caravan
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter...
1997 Honda accord nothing on instrument cluster works,only the battery light. Power windows will not work. shift lock solenoid doesn't work.Digital clock does not work. Lights on the console shifter don't light up. Help!
Aug 29, 2011 | 1997 Honda Accord
I have a 2008 gmc acacia. The front and mid auxiliary power outlets don't work. The fuse box is on a horrible location. I can't figure out which fuse it is and I don't want to spend hours...
{: ) At the underhood fuseblock, the AUX PWR fuse 20amps is for the Instrument panel and center console outlets, while the RR APO fuse 20amps is for the rear console and rear power outlets.
If your vehicle is equipped with an accessory 110vac, there is this PWR OUTLET fuse 25amps also at the underhood fuseblock. See red arrows on the sample diagram below:
wyet_helps_12.gif Safety reminders: Use only fuses of the same specifications. A higher fuse rating replacement can heat the wirings and could cause fire.
Jul 21, 2011 | 2008 GMC Acadia
My Wii won't turn on
This could be 3 things
1.) Blown Fuse
2.) Bad Power Cable
3.) Power Surge.
1 & 2 you would either need a replacement or a fix.
Number 3, unplug the system for 30 seconds and then plug it back up again.
Goodluck and I hope I helped!
Apr 11, 2010 | Nintendo Wii Console
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
Changed video games and then it would not turn back on. No power to the wii box.
((Contact Nintendo for a repair ticket if the unit has failed))
Nintendo Wii Console Logo
96 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
