Sony KV-32XBR96S No picture, or sound
I was wondering if I could get some advice for this. I noticed a few weeks ago that my picture was blacking out, but the audio was fine. One day my Wife tapped on the top of the tv, and the picture came back on. Well the problem came back that night, and my Wife tried the same "method" and basically lost everything power included. Now she barely tapped it I know this because I was in the room when it happened. I tried unplugging it and waiting and plugging it back in, but to no avail. When I plug it back in I can hear something power up in the back of the set, but there is still no activity when I hit the power button. I did however notice that the stand by light had come on (very dim I might add) the last time that I tried to power up, but only when I had my finger on the power button. I had a repair man over here to check into it, and he couldn't find the culprit. He told me that he had checked all of the usual suspects for Sony models, and everything had checked out ok. I ordered the service manual, and checked the troubleshooting section, and found nothing as well. I have very limited experience with the inner workings of a television set, but I would love to learn. Any help or advice for this situation would be greatly appreciated. Thank you John I dont have the same problem as above person but mine is with the Sony kv-32xbr96s.When I turn on the tv,either with the remote or power button,all the tv will do is click real fast and eventually gets slower and finally the tv will start to come on and off but with a loud snow white screen,unti it finally stays on with a picture.Occaisionally it will do this throughout the day.I dont know what else to do.Is this worth fixing? Thanks
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound, flashing standby light, will not turn on
sounds like powwersupply issue. repair is usually reasonable from reputable repair shop. id say around 150 - 250
Jun 02, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV-32XBR96S Wont power on,Just makes clicking sound
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
Nov 30, 2008 | Televison & Video
Sony Trintron Model # KV-27S22 Flashing screen
Hello
I got it fixed today at the TV repair shop down the street.
Thanks
Nov 11, 2008 | Sony HT-DDW840 System
My tv won't come on
the picture tube did not go
this could have been the flyback transformer and or some components, but the tv will need to be tested to determine what has cause the tv not to come on
Oct 15, 2008 | Sony KV-36XBR400 36" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Sep 09, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
