Question about Flotec 1/6 Hp 1260 Gph Utility Submersible Pump
I have a Rigid 1/6 HP submersible pump that stopped working
I left it running and water ran out. Does this have a fused? I can't seem to open it. It has a alan nut on the top that I removed as wel as all other screws.
Thanks
Mike
  • Anonymous Nov 30, 2008
    flotec 1/6 hp 1260 gph utility submersible pump
  • Loringh
    Loringh May 11, 2010
    Hi cowbugs:
    A lot of these submersible pumps will fail if they are in a situation where there is not water. Most are not built to be taken apart.I have one that cycles a fountain in a small garden pond. The little pond ran dry and the pump would never run again. When I installed a new one it stated on the box, "Do not run pump without a water source"
    can I ask what you are using the pump for?
    Loringh
5 Suggested Answers
gotgeek2
  • 565 Answers
SOURCE: I need a power cord for my 1500 gph 1/6 HP Flotec submersible pum
Get ready for sticker shock:
http://www.abtecparts.com/simer_cords.htm
Simer and Flotec parts are interchangable.
Posted on Feb 24, 2009
  • 634 Answers
SOURCE: Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Posted on Jul 17, 2009
  • 990 Answers
SOURCE: How do you remove the motor from a Flotec FPS5172, 1-1/2 HP.
The impeller screws on the motor shaft. First replace the through bolts in the motor. These are the long bolts, they will just cause headachs. On the back of the motor their will be a place to hold the shaft from turning, If you hold the shaft the impeller just unscrews. If you look in the center of the impeller it may have a set screw holding it to the shaft. If you have one of these it will be a left hand screw. Then you will need to break the impeller free as the brass that holds the impeller on will stick to the stainless steel of the shaft. Don't let how tight this is fool you when you put this back together it just goes on hand tight. Good luck
Posted on Nov 28, 2009
heatman101
  • 43501 Answers
SOURCE: submerseable sump pump works well...but, keep
The pump will usually run a little stream of water out at the rear, no worry about that...
The reason it will not shut off is because the float is stuck or the float is bad...
Tap on the float and make sure it can go all the way down...
If it still does not shut off then the float needs to be replaced..
heatman101
Posted on Mar 23, 2011
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
I have a Little Giant 6CIA submersible pump for about 3 years now, used once an in a trap in the basement waiting for a flood. Tried to test it today submersed and it would not work, banged it around a...
This pump works off of a pressure switch. You can remove the cover on the switch located on the side of the pump.You can either buy a switch repair kit, or you can open it up and take a look and see if the diaphragm is sticking. If you remove and clean the parts, you may have some success. Or, just buy the switch repair kit from your local Little Giant dealer. Good luck!
May 02, 2017 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
The motor keeps stalling. works for a short time & fan stops
Seem like the motor overheating and the motor protector make the pump stop,
Check if there is any physical damage on it,
Is it a very old pump?
Sep 18, 2010 | Tsurumi Pump s Submersible Trash Pump -...
I have a submersible water pump It seems to suck ...
That is pretty much par for the course with a submersible pump. Eventually the pump will be damaged by running dry as it depends on the water to keep it cool. Can't you set it up a little on something so it won't **** dirt?
May 20, 2010 | Garden
My Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
My irrigation pump starts runs for a minute or so than stops after several minutes it repeats this cycle. it is a submirsible pump. I have checked the pump start relay and it appears to be functioning. Any...
Of course, the pump start relay is okey. Your submersible pump is either overpumping/ or overloaded. Check the amperage while pumping using a clamp ammeter. Set it at 50 or 100 amp. Note the reading in amperes and compare this with the rated current posted at the pump control. It should not exceed the posted rated current. Assuming it is okey, then, it is overpumping. Your submersible is
drawing more water than what the well produces.
Solution:
To correct both situations, run the submersible pump
with your gate valve at full close position, and slowly
open the gate valve, until the pump runs smoothly.
Try it with the gate valve 1/4 open. Count the number of turns to get it full close from a full open position.
Divide the number of turns by 4, and the result is the
number of turns to open for you get 1/4 open valve.
Just send your e-mail for further assistance. God bless u.
Oct 26, 2009 | Plumbing
Pump is leaking oil
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Flotec 1/6 Hp 1260 Gph Utility Submersible Pump Logo
461 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
