Question about Kitchen Ranges
Maytag CHE9800BCE range - oven element not working
Right after the turkey was done (thank you, Lord), the lower element quit. Is this the only part I need to look for or are there other things that should be checked. I could also use advice on replacing the element as the owner's manual is worthless.
Found a local parts/service store that helped me. Replaced the lower element. Problem solved.
Posted on Nov 29, 2008
My Maytag convection oven has the heating elements on the top. It doesn't matter if I use convection or not, metal, nonstick, or stone pans, or lower the temperature or cooking time, it doesn't cook/bake...
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?
You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.
Your oven sensor or thermostat might be at fault.
Oct 20, 2013 | Maytag MGR5770 Gas Kitchen Range
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
We have a Maytag Gemini double oven. The lower element in the upper oven is not working. Tried replacing it, but that didn't work. It's getting power and everything. Any suggestions?
You may have a bad oven sensor. If you look in the oven you will see a small probe about the size of a pen that is the oven sensor. Hope this gets yu going in the right direction. Thank you for using Fix ya
Jun 24, 2011 | Maytag MER6751A Electric Kitchen Range
My lower over has been pre-heating for 2 hrs and has not gotten above 250 degrees - turned top oven on and it heated right up as always- trying to cook the Christmas Turkey and it will not fit up top--...
Sorry to read about your problem, I hope this helps you out.
wer
You may have a defective coil or probe...
But cut the turkey in 1/2 and lay on sides for top unit.. you will have a great turkey and wll cook faster
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag mod che9800bce range use oven get f 7 code
Hello there:
this error code is refferring to the touch pad
F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC
Sep 27, 2010 | Ovens
Lower bake element partially working
Is it a maytag?
https://m.youtube.com/watch?v=YReGvuOrSFU
Apr 07, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Maytag 500 electric smoothtop
lower elemnet in lower or upper oven??, should be an expused elemnt 2 screws on back wall of cavity should remove it forreplacemnt.TURN OFF POWER FIRST it is LIVE!!!!!!!!!!!
Feb 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Uneven heating in our Whirlpool range
on bake setting only your bake element is on broil element comes on for preheat only naturally the top part of your oven is hotter heat rises take the temp in the center of oven with a good thermometer
those cheap ones are a guide only dont swear by them
Dec 06, 2007 | Kitchen Ranges
Kitchen Ranges Logo
270 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
