Question about Kenmore Elite 45986 Front Load Washer
Standing water my dishwasher has about an inch of water in it. What do i do??
  • 116 Answers
IS THIS A DISH WASHER OR WASHER EITHER MUST CLEAN OUT PUMP PROBABLY CLOGGED W/ DEBRIS.............
Posted on Nov 30, 2008
Standing water in dishwasher
Good Afternoon friend, thank you for your post!
I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
Mar 11, 2015 | Frigidaire Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
I have standing water in bottom of GE GSD 666 dishwasher. I pressume I need to clean screen/filter? How?
I have the same problem, same model GSD660G0322. Have an inch or two of standing water. When I run the drain pump in Service mode, it successfully clears the water. How do I access the filter to clean?
Oct 22, 2011 | Dishwashers
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
JET TECH/model F18/small amount of water stays in bottom.Wont fill or cycle but water runs.
It is normal to have 4 or 5 inches of water inside the dishwasher unless you remove the stand-pipe (located inside, front right side). This pipe should be removed at least once a day and the dishwasher should be drained. Don't forget to turn the power off first.
For more info goto to
http://www.mvpgroupcorp.com/jettech/support.htm
Robert
May 11, 2009 | Jet Tech Systems 24 in. F18DP...
Water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher does not spray hot water
Can you give me a little more detail?Is this part inside or outside the machine?Any wires connected to it?What do you mean by base water source?I'm a hobart tech.
Feb 25, 2009 | Hobart AM14-253 Free-standing Dishwasher
Dishwasher tap off
We've always left ours on until the wash was complete as there are a few times throughout the cycle that need water.
Mar 15, 2008 | Danby DDW1805W Designer Series...
Kenmore Elite 45986 Front Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
