The set has a self check--try this(posted by another expert here):
"Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected"
SOURCE: WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
SOURCE: WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
SOURCE: Mitsubishi WD-65731 DLP HDTV , status indicator
Chassis V33. Says DM board short detected (error 59). Could be power short on DM, or communication line short. Should get diagnosed by repair shop or MITS service.
SOURCE: constant flashing red light on my WD-52525
Replace bulb, clean all vents and cooling fans of dust.
SOURCE: mitsubishi wd 65735 - blinking green LED on front
hello,
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Power supply board just die.It can be
dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power
supply board for the replacement.
Good luck..
