Question about Bosch HMV9305 Microwave Oven
Doesn't work It stopped working midway through a cycle and all lights went off. Unit felt hot to the touch above controls. Smelled a bit of burning so assume fuse or worse is gone. It's been making a funny sound for a while, seems overly noisy.
  • Bosch Master
  • 9,098 Answers
Sounds like your magnetron has failed and was going bad for some time.
I would contact Bosch to find their nearest authorized servicer.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Posted on Dec 02, 2008
My ge cafe microwave has stopped working after hot oven was on
you are most likely correct . they were not made to withstand extreme heat from the outside
Sep 15, 2017 | GE CVM2072SMSS Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
Amana ACO1860AS microwave
(I'm answering this directly via e-mail, too, but would still appreciate your kind rating)
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
Aug 28, 2008 | Microwave Ovens
Microwave quit working
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be the high-voltage rectifier diode.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
Feel free to post your brand and model so we might be able to give me specific info.
Nov 21, 2007 | Microwave Ovens
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave don't work
You didnt mention if the oven worked or not. Its not blowing the fuse?? Ok it could be as simple as the Diode or capacitor but dont try to touch the capacitor terminals as it holds a nice charge.. Turn on the oven for a bit with a cup of water inside and let it run for a few minutes. If you start to see smoke pull the plug right away!!!!! If you dont let the water boil(about 2 to 3 minutes thyen unplug and carefully fell around for a HOT part, But dont touch any electrical connections! If theres something drawing to much current it will get hot. Ive had bad capacitors bad and causes the transformer to get too hot. as well as bad magnatrons cause the transformer to get to hot. I would recomend that you take this unit in to be diagnoised as there are alot of voltage in this oven as I ststed before and it is dangerous for a handyperson to be fiddling with it. Good Luck
May 30, 2006 | Sunbeam SBM1000 Microwave Oven
Bosch HMV9305 Microwave Oven Logo
309 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
