Question about Samsung SyncMaster 740N 17" LCD Monitor
No display. the monitor gives no display although the power light is on[not on/off/on and so on]. i took out the PSU and i don't see anything wrong with. 3 capacitors are a bit deformed but nothing serious. is it dead and i should move on or is there something i could to?
  • louisxiv Dec 15, 2008
    same problem with 3 capacitors 820 microF. also, detected burned fuse - F301 (probably 3 A) and short on C231 (5,2 microF) even he's not on the print. any idea? thanks.
    Genius:
  • Samsung Master
  • 1,550 Answers
If the capacitor are deformed maybe are in bad conditions,overheated and probably the cause of the problem replace them
Posted on Nov 28, 2008
Computer powers up but no signal to mointor and the perphial accessories work but the power button doesnt com on or turn off the power
Unhook everything but the CPU, memory, and video.
Does it start up? Can you see anything on the monitor?
When you were messing around inside the box, you may have accidentally removed the wires from the motherboard that control the power switch and the power light. Check that you haven't done that and if you have, reattach the little plugs to the pins where they belong.
If you don't get anything, the motherboard is probably toast.
Jan 07, 2012 | Acer Aspire T180 PC Desktop
After power on no display on monitor & key bard not illuminated, only CPU fan running Please give solution Thanks,
If your working with an adapter video card better unplug the card and insert your monitor video cable to the onboard port on the VGA port. If that helps maybe your video card is defective or need cleaning or just loose on the slot.
Better also be sure that your PSU (Power Supply Unit) is good. It is not an indication when all your fan is moving and indicator lights are up that your PSU isn't defective. There were so many cases like this where most everyone jumps into conclusion that their motherboard is the problem and after replacing it with a new one they face the same problem. You should test your PSU to other working unit.
If your sure that your PSU is ok, better test you CMOS battery or replace it with a new one.
Hope this helps. Any vote is highly appreciated. Thanks :)
May 30, 2011 | Gigabyte GA-8I845GV-C (GBSA4LB)...
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
If pluged into light not powering at all
Firstly insert the battery. When you plug the PSU into the machine does a charging light turn on? If not then check the fuse in the mains plug as it may have blown. If the fuse is OK then you may have a defective PSU, although the motherboard could also be defective. Try a new PSU to determine if which component is faulty. <br /> Now remove the battery and insert the PSU. Will the machine turn on or do any power lights illuminate? If power lights illuminate and the machine will not turn on then I would suggest the motherboard is at fault. If the machine turns on briefly the turns off before displaying the splash screen then I would suggest the RAM, CPU or motherboard is at fault.<br /> If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit on the motherboard is fried.<br /> Hope this helps,<br /> www.PuterCare.com<br />
Aug 30, 2010 | Dell Latitude D600 Notebook
Why when i switch my hp 6720s on does the battery light flash amber then goes white nd the laptop switches off? all in 5 seconds
It sounds as if the battery is too low to power the unit on.
If the unit works without the battery installed then it is probably a battery problem, although it is possible the charging circuit n the motherboard is fried.
Hope this helps,
www.PuterCare.com
Jul 04, 2010 | HP Compaq 6720s Notebook
My Acer Aspire One model D250 cannot power on even if i already put the power adapter.Is it the battery pack problem or the motherboard?
Hope this helps,
www.PuterCare.com
Jul 03, 2010 | Computers & Internet
PC will POST, but no monitor display
Maybe you forgot to connect extra power to the graphics card? On that card I believe it is a PEG connector, some older cards used standard molex but this is a rather new card.
Also, some mainboards have extra power connectors for the pci bus to provide extra stability (mostly for SLI/Crossfire configs). Never hurts to check if this is the case and then plug in some more juice even if you are not using dual gpu's.
Good kuck and please come back with more questions if it didn't help-
Jun 02, 2009 | ASUS Computers & Internet
Power supply
There wouldn't be anything from the PSU giving power to your keyboard and mouse. The mobo handles that unless your giving your mobo the wrong amount it needs which might be why your P2P and USB arn't working. Although it is odd that your mouse isn't working with P2P as that requires less power.
Sep 29, 2008 | Compaq (243890-001) 250-Watt Power Supply
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
Pc wont turn on
removed hard drive, floppys , extra memory all pc cards
everything you can and try it again
Jan 18, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Samsung SyncMaster 740N 17" LCD Monitor Logo
169 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
