Question about StarTech.com StarView SV211K 2-port KVM Switch
Does eny 1 have the new codes for the d boxs - StarTech.com StarView SV211K 2-port KVM Switch
  • SEZLEZ26 May 11, 2010
    hi dose any 1 have the coeds for the starView box as my 1 went down to day its on Virgin Media (TW)
5a 01
04 4D 6F 7D D5 C9 F7 9B
16 CF 0C A7 A7 14 D2 22
Posted on Nov 28, 2008
O signal
Hello My Dear::":":
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 21, 2013 | Nokia 6710 Navigator Cell Phone
Got a lowry tv an bought a new remote no instructions in box for code and how to set it to tv eny help please
had same problem and googled it han found codes to reset my remote. might try that. Good luck
Aug 12, 2012 | LeapFrog Televison & Video
Chipset us very hot and no eny pictuer in monitor why?
You need to perform a quick check of the following steps for us to understand the exact status of your SMPS(power supply) and Motherboard
1) Open the CPU and check whether the green light is glowing on the motherboard when power is given to SMPS.
2) Please make sure that the HDD IDE/SATA and power cables are plugged in properly on both ends.Use common sense to check, do not press very hard as the slots are sensitive.
3) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
4) Make sure that the Jumper setting on the back of the HDD is set to MASTER. NA for SATA.
5) Login to bios and make see if you can find the HDD from the drives menu. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels.
6)Check the RAM are tightly inserted in the slots.
Close the box and restart PC
Jan 20, 2012 | Computers & Internet
Hi how do you check carburttor float in kx100
I av a kx 100 2002 i think starts straght away just splutters alot wen takeing off an not hittin power band can eny 1 hellp me asap aint tryed out yet guna trya spark plug today eny uther things ya culd think it culd be please get bk asap thanks matthew :-)
Jun 17, 2011 | 2005 kawasaki KX 100
Enie
Desired Letter
How to Make It:
In MSWord
3 number code
Hold down theAlt key and type:
4 number code
Hold down the Alt key and type:
Spanish
á
Ctrl+' then a
160
0225
é
Ctrl+' then e
130
0233
í
Ctrl+' then i
161
0237
ñ
Ctrl+Shift+~ then n
164
0241
ó
Ctrl+í then o
162
0243
ú
Ctrl+' then u
163
0250
ü
Ctrl+Shift+: then u
129
0252
Alt+Ctrl+Shift+?
168
0191
Alt+Ctrl+Shift+!
173
0161
May 02, 2010 | Toshiba Sattelite A105-S2071 Notebook
My turbo gto manual crunchs in ta 3rd evry time
if it only has problems going into 1 gear, it's most likely the synchro for that gear inside the transmission. but if this appeared out of thin air immediately after the hydraulic change, then i would definitely try re-bleeding the system first
Sep 29, 2009 | 1991 Mitsubishi 3000GT
Error (800230170
The code means that the PSN is under maintanence. Try again in a couple of hours and it will work.
Jun 30, 2009 | Sony PlayStation 3 40GB System
Incorrect code for radio. Where can i get a new code?
If you tell me the model number and make of radio i may have the right code
contact me at 07821810506
Apr 09, 2009 | 2001 Volkswagen Golf
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
