Question about Konica Minolta DiMAGE Z10 Digital Camera
Compatibility of sdhc card with konica milota Dimage Z10
Just wanted to check if sdhc card is compatible with konica milota Dimage Z10
  • Anonymous Dec 09, 2008
    I got a 4GB toshiba SDHC card and doesn't work
  • 1988MCSS Jan 24, 2009
    I have two 8G Delkin SD cards and neither work. Formatted both according to users manual AND through my computer still no luck
    Brigadier General:
  • 3,006 Answers
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Posted on Oct 06, 2010
Dimage Z10 won't read card
What type and size card? The Z10 uses SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Jun 29, 2013 | Photography
Konica minolta DiMage Z10 doesn't recognize sd card
Might one enquire how you have assessed the intelligence of the connecting lead ? I know of no definitive tests for this area of electronic equipment.
Mar 16, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
I purchased a new memory card and after putting it in the camera, an error message popped up saying that the camera could not read the card. I tried it in another camera as well and got a similar error...
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 21, 2011 | Konica Minolta DiMAGE X50 Digital Camera
Have a minolta Dimage 10X digital zoom 3.2 megapixel camera. When I turn the camera on it gives me the message can't read card.
Assuming this is an SD card, it may be that you are trying to use a high-capacity SDHC card in a camera which doesn't understand it. SDHC is not backwards compatible with SD.
A card with too large a memory may cause this message, even if it is a compatible type. Memory sizes have shot up recently, and even relatively young cameras may not be able to cope with the memories offered by the latest cards.
Another possibility is that the card (if new) has not been formatted, or (if used before) it may have become corrupted. The solution here is to format it, using the camera's inbuilt function for this purpose. This will effectively erase anything on the card, but it sounds like you have lost that anyway.
Oct 25, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
Camera doesn't acknowledge card when inserted into camera
Hi
Whats the capacity of your memory card? check for compatibility of card, since memory cards that have 4gb to 8gb are not compatible with some cameras. check as well from your cameras manufacturer if they have a firmware that will support such cards for your device/camera.
Hope this helps
May 10, 2009 | Konica Minolta DiMAGE A1 Digital Camera
Konica Minolta DiMAGE Z10 no sound?
because this particular model of the Z series does not have a mic. recording. kind of a waste but if you went to another model (I.E.. Z2) it does have the mic. to record. sorry but i went through the same issue myself. good luck
Mar 18, 2009 | Konica Minolta DiMAGE Z10 Digital Camera
Memory card size
I have a Z1 and I use a 2Gb SD card. The new SDHC 4gb don't work. I bought one but was able to fit it in my daughters camera.
Feb 12, 2009 | Konica Minolta DiMAGE Z1 Digital Camera
KONICA MINOLTA DiMAGE 7i COMPATIBLE COMPACT FLASH CARD
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
Sep 22, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Sd, sdhc memory cards is there a diff?
Omlt the Manual for the particular camera will tell you what its Max capicty is.
Dec 30, 2007 | Konica Minolta DiMAGE Z10 Digital Camera
What SD Memory Cards or Multimedia Cards are compatible with DiMAGE Z3?
The following cards have been fully tested. SD Memory card: Panasonic, Toshiba, Sandisk MultiMedia Card: Sandisk, Hitachi For more information about the latest compatibility, please refer to Konica Minolta web site.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE Z10 Digital Camera Logo
954 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
