Question about HP Pavilion dv9000z Notebook
Laptop boots then shuts automatically off
My laptop boots but after a few seconds it completely shuts itself off. my comp keeps P**** me off, i restart and it wont boot up, the lights come on, then it shuts off, then boots up, nothing on the screen (again) then shuts down.
I cold boot it a couple of times, eventually the screen comes up and its fine
like wtf? lol why does it do that, i have no virus's
  • 2 more comments
  • bblume Nov 28, 2008
    I have the identical problem. My HP Pavilion notebook (dv9000) worked a couple times yesterday, but started seizing up and now will not power up after shut down. As yours, mine will try to come on but after about 15 seconds will shut down and try to restart in continuous cycles. I noticed there was a Vista upgrade that automatically downloaded the night before... not sure if this caused it, but I think HP knows of this issue. My notebook is 2 years old, and now they tell me I am eligible for a one time "Limited Warranty Enhancement Program", and they are sending me a box to return to them for a free service of the problem. Call them: 800-474-6836 maybe you will get the same deal.
    I just became aware of the HP "Warranty Enhancement" announcement/link:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
  • samirebr Jan 29, 2009
    exact same problem - tried taking out memory and re-inserting, and taking out battery and turning on without - same problem. boots to black screen for about 10 seconds and then dies. but sometimes it comes up fine - what do i do!?
  • Mark Robinson May 11, 2010
    any error messages or beeps ?
    might be worth taking out the ram chip and reinserting it....I see a lot of these types of problems in dusty environments
  • HP Master
  • 5,568 Answers
If you haven't tried it yet, pull the battery out and try booting from the adaptor only. If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge. Under normal conditions, they should measure a couple of percent higher than their rating. You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
Posted on Nov 28, 2008
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Why does startup repair keep popping up on my laptop when i turn it on my sony laptop
This is the system error and it comes when the user doesnot shut the comp in proper way.//
it can also come if due to some reason the comp is shut automatically//
to get rid of it try last known good configuration.
shut down the comp// restart and immed start hitting f 8 cont to get the advance boot menu//
select LKGC and once that is done hopefully your computer will boot perfectly//
May 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Automatic update is not completing and is keeping me from logging
Dear Friend,
I strongly Recommend you to TURN OFF automatic Updates if YOU ARE USING NOT GENUINE COPY.....This will block your System after updater...
  • Computer might Infected Virus
  • Scan with good Anti virus
  • Uninstall any Newly installed untrusted Software/Softwares
You are done....you may feel Free contact.....
Is this Helped you...
thanks for Using FixYa
Apr 01, 2010 | Acer Aspire 5315 Notebook
Keeps rebooting
got wet ? bad board .
Jul 12, 2009 | Motorola Mobility RAZR V3
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Try this, if you have a fast hand, the second it boots, push Ctrl+Shift+Esc and end taskeng.exe.
If you can't do it fast enough, try booting into safe mode, going to scheduled tasks, and removing any suspicious ones.
If you don't know how to boot to safe mode, push f8 until you see a screen which allows you to choose safe mode.
Dec 18, 2008 | Toshiba Satellite P105-S6177 Notebook
Will not start up
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Sep 09, 2008 | HP Pavilion dv9000z Notebook
Problem During Boot-Up
several things it could be but im going to look at the obvious the battery and cord hook up
laptops when plugged into contstant 120 power the battery is supposed to go into stand by mode and shut battery off so power dont leak into battery
if you have low battery with it plugged into 120 the comp will still think the battery is powering the laptop if battery dead then comp shuts down lack of power
other thing is somehow you caught a virus that reboots comp from dos screen mode
the main thing i always ask is what was the last thing that happened before it did what its doing now
example= was there a power surge pop up screens ect.
May 09, 2008 | Toshiba Satellite A75-S231 Notebook
i thinkl you got a virus,, i suggest you to restarted than scan your computer.
Feb 23, 2008 | Toshiba Satellite A85-S107 Notebook
HP Pavilion dv9000z Notebook Logo
963 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
