Question about Whirlpool ED2FHSS Side by Side Refrigerator
Whirlpool side by side refrigerator - grinding noise from icemaker
Icemaker makes continuing 'grinding' noise, whether on/off bar is in either page. help!
  • 237 Answers
That would likely be the ice maker "motor module". They are notorious for failing. The plastic gear on the front pulls away from the contact springs from ear tab failure, etc. It's an easy fix to replace the whole module (about $70 bucks). See the diagram here. http://www.partselect.com/Schematics/Whirlpool/THIERSZO.gif
Posted on Jan 15, 2007
  • Marc Wilson
    Marc Wilson Jan 15, 2007
    Item 35 is the whole motor module, it's similar on many many fridges.
My refrigerator makes a whirring noise.
If you have an icemaker, this sound may be the inlet water valve to the icemaker opening and closing.
Sep 18, 2014 | Whirlpool Refrigerators
Icemaker making noise
check that there isn't any ice stuck inside the icemaker teeth.
Apr 24, 2012 | Whirlpool Ice maker 4317943
Whirpool icemaker making noises but not producing any ice
Hi
Please check the bellow links to trouble shoot your problem when the icemaker is not making ice:-
http://www.ehow.com/how_4844376_troubleshoot-whirlpool-refrigerator-ice-makers.html
Also check the bellow link for whirlpool icemaker repair guide:-
http://www.appliance-repair-it.com/Whirlpool-icemaker-repair.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Refrigerators
Icemaker rakes not moving, though it is in the cycle and making a lound humm, grinding type sound (similar to when it does its normal ice rake cycle.
Normally, icemakers make very little noise. If it is in the middle of a harvest cycle and will not complete the cycle, remove the icemaker and look to see if an object some how fell into the ice cube mold area, preventing the rake from turning. If there is no obstuction, you will have to buy a replacement icemaker, as there are no replacement parts available. NOTE: Do not leave the icemaker in your freezer in the middle of a cycle for extended periods, as the mold heater would be "on" and adding heat to your freezer section the entire time, causing your refrigerator to work harder than normal, and costing more to run.
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I emptied the ice from the icemaker into a cooler and then the icemaker quit working. The bar that drops to make ice, seems loose.
The bar that drops has to lock into a plastic clip to activate the switch. Try seeing where it locks into the clip and it should just line up and push in.
Dec 29, 2009 | Whirlpool GD5SHAX Side by Side...
No ice is coming out of ice maker
  1. Whirlpool Icemaker Repair Guide ... guide I will walk you through the steps in a whirlpool icemaker not making ice. ... when you do this water does enter the icemaker take that jumper wire and place ...www.appliance-repair-it.com/Whirlpool-icemaker-repair.html - Cached
Dec 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool Gold Model GS5SHAXNL 00 makes loud grinding noise about every 40 minutes
I would check your ice maker. You can shut it off by slidding the control on the right hand side of the freezer wall. If the noise quits you need to repair the icemaker. In door ice has had some problem with their icemakers. If that is it they make a kit part #8201515 that will fix it.
Sep 15, 2009 | Refrigerators
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ice maker no longer makes ice
That could be caused by a number of things. Freezer temperature is too high, The Tube that feeds water into the icemaker could be froze up. Bad Water Valve. or Bad IceMaker.
Ensure the the Bar on the side of the icemaker can go completely down, against the side of the icemaker.
Let me know how you make out.
Bill
May 17, 2008 | Whirlpool Refrigerators
Whirlpool ED2FHSS Side by Side Refrigerator Logo
559 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
