Question about Alpine MRD-M300 Car Audio Amplifier
Led read out
On my amp there is the read out [b]e-3[/b] does any body know what this means and how to fix it.
  • Anonymous Oct 06, 2008
    Why would there be a exceeded current? Where do you start to look for the reason!
E-3 The amplifier has been shut- down due to excessive current. Find and eliminate the cause of the excessive current, then turn the power off then back on from the remote control unit.
Posted on Oct 02, 2007
Do you consider yourself Psychic?
We All have psychic ability; not everyone is aware 'what that means' (there are different 'levels' of psychic experiences & or clairvoyance or clarity) Research Edgar Cayce on youtube & read about his life (I go to the Edgar Cayce Center A.R.E.)
*its does not matter about people's strong negative Dogmatic opinions against psychic phenomena; they are close-minded souls.
Yes I have psychic abilities & the more I become aware & 'listen' > the stronger I become (meditation & prayer & detoxing my entire body & mind & life style 3 yrs ago started to ripen my abilities plus I go to the Edgar Cayce Centers & Lily Dale & I am learning to work with Crystals now< google those places)
* 3 eye chakra (pineal gland detox)*
"Be still in slience & know"
Jan 04, 2017 | Horoscopes
MY OLD DELL DIMENSIONS 4600i DESKTOP KEEPS READING WRITE/READ FAILURE AT CHECKPOINT [PnP1] AND DOESNT REBOOT WHAT CAN I DO?
re seating the memory card could fix this issue, however look at back of the desktop and you should see 4 led's (diagnostic led's) the sequence in which the lights glow will let you know what the issue is
for eg GYYY - means memory is not detected ( Green, yellow, yellow, yellow)
Oct 20, 2013 | Microsoft Windows XP Home Edition
Alfa 156 2lt JTS fault codes P0120 & P0505 are they an easy fix?
p0120 means you have a throtle position sensor problem could get expesive if throtle body is bad p0505 is same problem it means throtle idle controle valve problem hmm short bad ecm or bad throtle body hope this helps
Nov 27, 2012 | Cars & Trucks
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
There is a engine noise coming out from my speakers
(1) If you have an ohm meter check from neg terminal of battery to body of your car. It should be below 1 ohm. You should get the same reading between the amp neg terminal and the amp ground point. Check amp ground with the power off and the wire to the negative on the amp temporarily disconnected. Most cars have a braided uninsulated ground strap from the engine to the body or frame. In older cars this can break and it usually causes noise. Run a temp ground wire from the battery neg to the bat neg of your amp, if the noise goes away it's a ground issue for sure.
(2) Make sure the amp is well grounded ! The bolts that anchor the seats to the floor are one of the best ground points I know of.
(3) I've fixed a few amps that had an internal broken connection from the RCA's on the amp where they connect to the circuit board. This often happens from not having the amp bolted down and/or the RCA's getting hit or kicked. This will cause noise in the amp and requires taking the amp apart to fix it.
Apr 02, 2010 | Solid Audio Formula Series F4 4-Channel...
When I plug in my jet 3 ultra the ammeter reads 0. If I turn on the vsi controller the top led display( 3 red, 4 yellow, 3 green) are all lit. I see where that means high battery voltage. The lower led...
Its showing you the voltage out put for the charger if all power lights are lit and the chager is pluged in if batteries show only 2vlts then they are no good and the will not charge up thats why amp meter is on 0
Mar 03, 2010 | Jet 3 Ultra Power Chair
I have a Philips 42PF9630A/32 Plasma TV, red led blinks 7 times
No,body can cofirm u have to troubleshoot change the boards to know the problem.
Oct 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Amana heat unit led flashes code 3 what does that code mean
Can you find the manual and see what it reads? It would help allot, sometimes theyare on the furnace door somewhere, even inside the cabinent. Let me know, if not then we can go step by step to try to figure out your problem, and save you money for a tech to fix it.
Dec 06, 2008 | Amana Heating & Cooling
Amp problem
Are you sure that the terminal isn't shorted to the case of the amp?
If it's not, the amp probably has a shorted output transistor.
If you want to repair it yourself, read through the following page. It explains the basics. Let me know if you have any questions.
Basic car amp repair primer
May 15, 2008 | Lightning Audio b2.250.1 Car Audio...
Alpine MRD-M300 Car Audio Amplifier Logo
103 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
