Please sir,I will like to know what can give the cause for a motherboard not to display even when the v.g.a,memory[ram],processor,cmos battery on it are in order,but when connected on power the light on the board will come on, but it will not display.have tried all i could but nothing comes out of it.
  • sahrshekuste Dec 08, 2008
    thankyou sir for help as i have did what you said exactly but have findout that one of the chip on the board is gone and i think i have to get a new one,once more i say thanlyou.
    Scholar:
  • 83 Answers
Try to check your cable pin from the monitor to PC. Maybe one of the pins broke.
If you are using a video card, try to see if it is inserted in the video card slot. if problem still exist try to reconnect it to the built in video card slot of your PC. You may try also the monitor maybe its the problem. Switch on the monitor with out connecting the cable to the CPU. Check if some display will appear in the screen. If none its your monitor must be check First.
You might have forgotten to install the video card driver. it works best i you refer it to Technician on parts and accessories of Computers.
Thanks,
jonags3@mail.com
Posted on Nov 28, 2008
    Scholar:
  • 176 Answers
If the motherboard has also integrated graphics check the BIOS settings, u can set up with what video card to start. Are u sure all other components are good (including power supply )? Does it make any beeps ?
If all components are good and it still not working then the chipset or something else on the motherboard is bad, and u;ll nead a new motherboard....
I have a gigabyte p4 pc, when i power it on the fan runs but it gives out a continuous beep. checked ram, processor on another motherboard, cleaned the motherboard, checked for loose cards and cables
The continous beep usually means a memory failure (RAM) or video memory if a plugin card is used.
Check to be sure the unit sees all of the memory, a weak power source( without AC adapter) could cause a partial failure of one memory card.
Another fault would be that the battery is very low on charge and won't accept any charge.
BAD Battery.
hope it helps
May 31, 2012 | Gigabyte GA-8LD533 Motherboard
When i switch my pc on i have no display?
your graphicscard not working properly, broken.
monitor cable is fitted in the graphics port?
Mar 23, 2012 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
Display Problem with Intel 845GVSR MB : My computer running on Intel 845GVSR MB with 2.4 GHz Intel Pentium 4 Processor and 768 MB RAM and 80 GB HDD . When I start the computer nothing appears on...
Reset the CMOS setup after putting the battery. You have 768MB RAM. So check with the alternate memory module with different slots. If not helpful, check the RAM with another PC. Lastly get the BIOS updated or motherboard repaired from component level motherboard repairer. You may have damaged the motherboard by putting undue pressure while plugging the connectors.
sonsunny
Jul 08, 2011 | Intel D845GVSR Motherboard
After turend on there are 3 beeps, no display, ram are ok tested
It is a memory problem. Verify if they are plugged in the mainboard slot.
Jul 13, 2010 | Intel DG965RY Motherboard
HP Pavilion DV2000 no Display
First pull motherbord from cabinet some times motherboard is grounding with cabienet.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect ATX power connector to motherboard.
Then check.
If still same issue then open processor fan and processor then clean dust from all place in mothebord.
Then try.
If you still got same then something rong with your ram or motherbord.
Change ram then try.
Pull all card from PCI slot check motherbord only with RAM not even harddisk and other device.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
No display & beeps when power on
hi there,
looks to me you've got a faulty motherboard....but have you tried your memory,processor, and video card on another motherboard??? just to be sure....please try....
Apr 22, 2008 | Intel D845GVSR Motherboard
Intel motherboard crash
try to check if your memory (RAM) is compatible with your board. run dxdiag to see your computer specification
Mar 15, 2008 | Intel Motherboard
No display smps ram Processor ok
Did U try to unmount the CMOS Battery and shorting the CLRTC Jumper? If not, first check whether UR CMOS Battery is OK. If the Battery is more than 1 years old, try replace it.
Mar 11, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
332 people viewed this question
David Payne
David Payne
