Question about Magellan Maestro 4000 Handheld GPS Receiver
Magellan mistro 4000 will not charge battery
Unit wks with power cord mobil or house but i left it unplugged for 3 weeks and now it will not keep a charge, cannot find a replacement battery either. i have it apart,
Thank you
Dale
  • Anonymous Feb 08, 2009
    Need a replacement battery.
Battery part # 37-0030-001 direct plug in replacement at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
Posted on Jun 13, 2009
Device will not power on
I found a Magellan Roadmate in the dumpster when I was dumping the trash off my truck.They were even so kind to leave the charging cord.I figured out that the charging cord wasn't connecting to the unit when plugged in.It took 20 minutes to figure out how to pop the case open(retainer tabs on all sides in addition to the screws).Once opened up,it took 5 minutes to repair the solder connections from the power socket to he circuit board.Works like new!
May 31, 2012 | Magellan Roadmate 2035 4370 2036 4040...
Battery will not hold charge
make sure its charging by going in to the options tab, then system, then power options and look at the battery meter and see if its moving left to right while plugged in to the charger.
if its not,
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 06, 2010 | Magellan Maestro 4000 GPS
Battery does not keep a charge. Can the battery
yes, the batter can be re placed, but i would verify its charging before buying a battery.
make sure green light is on the car charger (or a known good charger0 and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
after its started, go to the system setting. the battery meter should be moving left to right. if its all green and turns off when unplugged, the battery needs replaced.
your part # for your battery should be 37-00030-001you can get a battery HERE but verify your unit with the seller.
if it only has a few bars and is not moving while plugged it, it is not charging.
this is a very common problem for the models listed below.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Nov 14, 2009 | Magellan Maestro 3140 GPS Devices
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
Nov 09, 2009 | Magellan Maestro 4000 GPS
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
you can get it repaired, here
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | Magellan Maestro 4000 GPS
My magellan crossover gps keeps shutting off in navigation mode - why?
make sure its charging..plug it in to a known good charger..go to the main menu, then systems options then power the power bar on the bottom should be moving from left to right..if its not, its probably the dc power port
If your GPS is not charging, the following models are known to have faulty power ports.
Magellan Maestro or Roadmate..800 860 2000 2200t 2500 3000 3050
3100 3140 4000 4040 4050 6000t
you can buy a power port HERE
or get it repaired HERE
bill
Oct 01, 2009 | Magellan Crossover GPS
My magellan maestro GPS unit won't hold a charge with the house charger. I charged it for over 6 hours last week and the battery was fully charged. Today I got it out and it's dead again. This unit is only...
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Jul 16, 2009 | Magellan Maestro 5310 Car GPS Receiver
Magellan Maestro 4000 will not hold a charge longer than 30 min
replacement battery at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
must remove external card from slot before removing 4 screws at rear of unit. cover snaps off, unplug speaker wire, unplug battery, new battery plugs in, reassemble.
Dec 27, 2008 | Magellan Maestro 4000 Handheld GPS...
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Magellan Maestro 4000 Handheld GPS Receiver Logo
330 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Mike Cairns
Mike Cairns
Are you a Magellan GPS Expert? Answer questions, earn points and help others
