Question about Nintendo Video Game Consoles & Games
Broken hinge and microphone not working - Nintendo Video Game Consoles & Games
    Problem Solver:
  • 45 Answers
Phone nintendo and they should be able to repair your NDS Lite for free
Posted on Nov 28, 2008
Broken left hinge
Finding a hinge is almost impossible, but you can do a fix on your broken one that will get your adf working properly again. Watch the video. Michael
Dec 03, 2013 | Lexmark Prevail Pro705 Wireless All-In-One...
The microphone is not working while the music works on the magic mic
twist microphone cover. Inspect and solder broken connection wires from the microphone to the motherboard.
Aug 28, 2013 | Magic Sing Along Consumer Microphone
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
"Compaq Presario CQ60-209tu inbuilt microphone
Hi, You may have to take apart the laptop to find the connection problem. In many cases it will be in the hinge. If you are not the fixing type brimg it to a PC shop. Good Luck.
Oct 02, 2011 | Compaq Presario 700 470024-192 Notebook
Have a beta 57a it wont work ? nothing
I'm assuming that you have tried the obvious stuff like using a different cable and a different amplifier?
The Shure beta 57a is a very robust and reliable dynamic microphone and there is very little to go wrong with it apart from
  1. A wire broken off inside
  2. A broken capsule - can be caused by dropping it
You can inspect for broken wires by very gently unscrewing the microphone head and peering inside - however the wiring is quite short so be careful not to pull any wires off in the process.
A broken capsule can be replaced - contact your local dealer for parts.
Feb 09, 2011 | Shure SM87 Professional Microphone
Mic test hs no volume bars how can i fix this
Nintendo DSi & Nintendo DSi XL - Settings - Mic Test
You can use this feature to verify that the system's built-in microphone is working properly.
How to test the microphone:
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow twice to go to page 3, then select "Mic Test."
  3. Speak into the microphone (the microphone is located on the center of the hinge).mictest1.png
  4. The volume bar will fill up with colored bands when it picks up sound.
    • If the volume meter does not fill up, check whether anything is connected to the headset port. If noting is connected and test still does not work, then there is likely a problem with the microphone and the Nintendo DSi will need to be repaired. Please click here for repair information.
    • If the volume meter responds, then the microphone is working properly.
Jan 29, 2011 | Nintendo DSi Blue Console
Left hinge is broken on HP officejet 6210
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Nov 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Broken door hinges
dont they have a replacement hinge to buy ? look for part at
appliance .com -- they have everything -- just look up item under the model number and unit name
Jan 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Microphone doesn't work
The mic is connected by a small white wire that runs through the hinge section. It can get caught in the slot the top screens ribbon cable goes in and get broken. This is the most common cause. However it is also possible the end connected to the board has come loose. But it's more likely that the wire has been broken.
Dec 26, 2007 | Nintendo DS Lite Console
Broken screen hinge/collar
You can purchase replacement hinges and hinge covers here: http://www.mundocorp.com/m275.html They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
Aug 28, 2007 | Gateway M275 Tablet PC
Video Game Consoles & Games Logo
62 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
