Arganto 82 TV Model MW 82-505 IRDT/DPL when turned on switches to standby after 2sec and will not switch on from standy (remote batteries fine).
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, the unit is reverting to protective mode to prevent further damage. This could only indicate that the unit has sustained some damage electronically and therefore would require service. There are no reset other than to unplug from the mains for an extended period of time.
A concerned note, the Grundig ARGANTO 82 MW 82-505 IRDT/DPL VNM TV is about 8 yrs old. Depending on your location, replacement parts and service personnel familiar with this brand and model might not be that readily available. Sorry, but you may have to consider other options other than repair.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 306 Answers
I suppose the problem is in the secondary of the power supply.. so better to leave it for service..
    Sergeant:
  • 291 Answers
Check out the socket where u insert the batteries some dirt at that place will be stoping the unit to start.
  • 19,396 Answers
That means that the TV detected an internal error and started a protection switch.
The protection swithc now is preventing the TV from turning on.
Try first unplugging power cord for ten minutes to reset the unit.
  • Ginko
    Ginko Nov 28, 2008
    Modern TVs have an inside device calld protection circuit.
    When an internal error , like for example a bbad voltage, a short, or a defective component (IC , capacitors etc.), is being detected, the TV protection circuit will start an automated switch that turns the TV on standby to prevent further damage.
    Sometimes the internal safety switch is just jammed because hit detected an incorrect value.
    In this case you can fix the problem and wake up your TV draining power from TV completely, by leaving the power cord unplugged for a while.
    Try first unplugging and waiting ten or twenty minutes.
    If that does not work try leaving the cord unplugged for a longer times, let say two to three hours, to drain power completely and get rid of electrostatic charges on internal circuits.
    If the TV does not restart after this then that means that there is really a faulty part inside that must be replaced.
    Common problems concern the power board, the convergence ICs, and, depending on the model the deflection circuits.
    The tv must be taken part, tested thoroughly by a technician, and the faulty part replaced.
    If you decide to call a technician, or you need to validate your warranty, or to buy a warranty extension, you can ring the phone number listed on the owner manual.
Mitsubishi DPL TV model wd73c8, serial 100759. The tv will not turn on & has a solid red light in status.
Try to turn it on manually by the power switch - not by using the remote control. Try to unplug it for an hour or more to discharge the power system, then try again.
Aug 02, 2016 | Mitsubishi Televison & Video
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
I have Grundig - ARGANTO MW 70-510/8DPL Television. I dont have codes for Grundig TV! My remote control: One For All URC 9960 B01 (Kameleon 8 Remote Control)
The philips universal code is 0218 for the Grundig Arganto 70
However, this misses two important buttons, the codes for these are below:
134, 142 EPG
212, 220 info
some others incase your universal remote doesn't have them...
006, 012 OK
020, 028 channel down
030, 038 channel up
004, 012 mute
133 aux
230 av
165, 173, 228, 236 1
239 2
237,238 3
102 4
100 5
103 6
039, 046 8
036,044 9
007,015 off
205 contrast -
206 contrast +
215, 223 sound menu
198 colour +
061 dig/ana
063 contrast
068 vol -
069 cont -
070 vol +
071 bri +
076 vol -
077 cont -
078 vol +
079 brig +
Nov 02, 2009 | One For All Kameleon 8 (URC-9960) EL...
TV will not come on via the remote control and remains in standby
Try switching it off at the main switch on the TV. Then switch it back on from the same main switch on the TV. If the TV then comes on & works normally, then check the batteries in your remote control, they may need replacing.
Mar 28, 2009 | Samsung LE32A41B 32 in. HD-Ready LCD...
SHARP 29" TV switching off to Standby
have you tried changing the batteries just to elimate this problem
change them
sometimes if the batteries are low in electronic devies, they send a wek signal to its receiver (your tv),
your tv gets confused and then switches itself to standby
if you have changed the batteries and this problem still persists
it can only then be th PSU or power supply unit, take it to your local tv repair shop of mastercare somewhere like that, its going to be cheaper to get it repaired than replacing the whole tv
PSU'S generally 20 to 50 pounds depending on model
don't deo it yourself though unless you've got a capacitor discharger (or a nice 25KV will be on its way to your body)
hop this helps mate, let me know how you get on
Nov 10, 2007 | Televison & Video
Magnavox 20MF251W won't turn on at all
my tv is not rurnine on the standby light is on
Aug 27, 2007 | LG MW-71PY10 71 in. HDTV-Ready Plasma...
Grundig arganto 82
You have a problem in the secondary of the power supply,no amount of switching on or off will solve this,it will have to go to service,
May 17, 2007 | Grundig GF70-600 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
