Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
I just bought a frigidaire upright freezer a week ago. I can't get a repair person to come look at it until monday. The freezer is cold on the bottom and warm at the top. I put water on the center tray and it took over 24hrs to freeze. I have the temp setting on 6 and the coldest is 7. I put a thermometer on the center shelf and it reads 20 degrees. I do not here a fan running but the freezer makes a whirring noise and has done that since I plugged it in. I don't think it has cut off the whole time I have had it.
  • eddiehoward Nov 28, 2008
    Thanks for the info but can you tell me where the fan blade might be?
  • 828 Answers
Since this is a new freezer it should be serviced by the people who sold it to you in order to avoid any warranty conflict. The fan blades of these units are of a slip fit onto the motor shaft. It is possible that the fan blade has come off the motor shaft.
Posted on Nov 28, 2008
  • James Helmer
    James Helmer Nov 29, 2008
    The fan is generally located in the upper section of the back wall of the freezer. There will be a plastic grill covering the fan motor and blade.
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
What number should i set the upright freezer control
Thank you for your inquiry, friend!
Normally it is recommended to set your Frigidaire upright freezer to zero degrees. It is your option to make it cooler if you choose too. I hope this information has been helpful. -Matt
Oct 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Our freezer sat in the garage unused and unplugged for about a year. Now we are ready to use it so we plugged it in. Its been on about a week now and its still not getting cold inside. Actually I...
something easy to try is to clean the evap. usually on the bottom. warm soap and water, or compressed air usually does the trick. it's the easiest thing to try.
Aug 21, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Just had a new upright Frigidaire freezer delivered two days ago. Plugged it in immediately. It did not get cold after several hours. Turned it off then back on. Unplugged it. Unplugged it for several...
Whenever you get a frig or freezer delivered it is best to wait at least 24hrs (some say 8 hrs) before you plug in. It maybe unknown to you if this was shipped to you in the laying down postion. If it was and you plugged in it will not work because laying down the oil migrated away from the compressor.
Other than that the freezer could have (possible chance but still possible) problems that are out of your control. If you brought it at a retail store you have at least 2 weeks to exchange. Do that a.s.a.p.
Dont bother trying to figure out just exchange!!!
hope this was helpful
Apr 04, 2010 | Frigidaire Freezer Refrigeration White...
My freeer stopped working after the temps dropped
freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
Feb 04, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
235 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
