Question about Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC)
Patchy printing I have tried using the cleaning kit and have changed the ribbon but the printing is still very patchy......flashes of odd colour blemishes appear on the photo images and the print is incomplete.
    New Friend:
  • 54 Answers
Problem is with either with cards or with print head's mechanical alignment. Try with some different cards and for head get it tested by some authorised service person.
Posted on Mar 23, 2010
I have a brand new zebra tlp2844 I have set it up with a resin ribbon, the print quality is very poor and patchy why is this ?
There are a couple of possible solutions.
1/ Resin ribbons are meant to be used on synthetic labels onle ie vinyl or polyester. If you are trying to print on paper labels then you will get a rubbish print. you need to use either a wax ribbon or a wax resin ribbon.
2/ If you are printing onto a synthetic labels and the print is light, try increasing the "print darkness" some times called contrast or heat or printhead setting.. This can be fount in the printer set up in the labels software you are using or in the print drive under "Print Preference"
Dec 16, 2012 | Zebra TLP 2844-Z Thermal Label Printer
Colour change on tevion tv
is all the screen the same colour or is it patchy. It could be the degausing cerquet (if patchy). Or maybe just to be degaused with a degausing coil.
Jun 01, 2010 | Televison & Video
Its printing patchy and ghosting
it will yes. I know with fusers and xerox you can usually reset the fuser. When servicing the machine the techy will do this for you:)
Nov 18, 2009 | Xerox Phaser 7400DN Laser Printer
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
My epson stylus SX200 2C will not print black , i have replaced the ink 3 times and cleaned it - it has a lot of gaps and sometine doesn't print black at all. Colour is fine. Help please .
I have excatly the same problem. I have cleaned the nozzles mutiple times and replaced the blck cartridge twice but I still have patchy printing in the black portion of the test print and horizontal banding in word documents
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Incomplete patchy printing
Please try to do a printer head cleaning. You can do it by getting a small earbud and soak it with a small amount of water. Or try to adjust it by doing an alignment. Usually, the printers have this functionality. Please refer to the user manual.
Aug 13, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
COLOURS WILL NOT WORK ON PRINTER
What does the nozzle check pattern show? If the check pattern is patchy or has lines missing then you need to clean the head. If you are using rubbish compatible inks instead of the genuine stuff then doing head cleans may make the situation worse.
See my previous post about under head cleaning and follow the instructions there.
If the check pattern is good you may be experiencing a common CX problem with one of the vacuum pipes. A rescue kit is available from tradebit
Oct 11, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Evolis Pebble 3 ID Card Printer Package (P/N MIDS-E-SC) Logo
299 people viewed this question
Top Evolis Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
