Question about Hotpoint Aquarius WMA42 Front Load Washer
M/C WILL NOT TURN ON
POWER SUPPLY CORRECT
  • martin_curle Dec 01, 2008
    IT WASNT WASHING MACHINE IT WAS TUMBLE DRYER PROBLEM STILL NOT FIXED
  • Hotpoint Master
  • 3,463 Answers
Hi.
Make sure the door locked light is showing, or it wll not work. If it is flashing all time, then you have an eletronics problem, Really need more info with symptoms
Posted on Nov 28, 2008
Casio LK-100 keyboard is turning off often when chords are played, esp in lower octaves - seems like a short. Where might the short be - way to fix without taking the whole keyboard apart?
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Jan 17, 2017 | Casio Music
When i turn off tv it wont go back on for hours
The most likely issue is your power supply is failing. Most likely issue that would cause this problem is bad capacitors on the power supply.
What happens in the above situation is:
After the Tv has been off for some time the electronics and capacitors are cool and supply the correct voltage so the TV turns on.
After using the TV the electronics heat up and the material in the capacitors expands causing the power supply to supply incorrect voltage. With the TV the power is flowing and is close enough to the correct values for the TV to stay on, after being shut off the TV will not turn back on because correct voltage is not present until the components cool down and the voltage at power on no longer engages the protection circuit.
Info on checking and testing power supply's
Info on finding and repairing bad. Damaged, leaking or swollen capacitors
Jun 07, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
It wont turned on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Mar 21, 2012 | Lexmark X2500 All-In-One Printer
My computer went blank when turning it on
1) Computer isn't working, due to the Processor isn't working, due to a bad Power Supply.
Weak voltage power rail.
Enough power perhaps to light LED lights, and maybe spin fans, but not enough power to turn the Processor on.
Computer Power Supply's are rated in Wattage.
Volts times Amperes = Watts.
(Average computer power supply in a fairly new computer, is rated at around 300 Watts)
A) ALL of the LED lights combined, use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts.
C) A typical Processor may use 51 to 125 Watts.
Depends on what Processor it is.
Power Supply with a weak voltage power rail, can have enough power to light LED lights, spin fans, but not enough to turn the Processor on.
Solution?
Test the voltages of the Power Supply,
Or, use a KNOWN to be good Power Supply, that has the correct amount of power cables, the right kind of power cables, the correct size, and shape of the case, and enough Wattage, for a test unit..
A bad Power Supply is one of the leading causes of computer failure.
Sep 19, 2010 | Computers & Internet
Code 803
E803 (The output voltage of the composite power PCB has a fault.) Cause Wiring Composite power supply PCB (J208) Continuity DC controller PCB Composite power supply PCB
• If it does not turn on, see "The scanning lamp fails to turn on." • If it turns on but is dark, replace it (its ends may be blackened). Correct the connection. Connect it securely. Replace the harness. Replace the DC controller PCB. Replace the composite power supply PCB.
Turn off and then on the main power. Is the problem corrected? Does the scanning lamp turn on when the Copy Start key is pressed? Or, is it dark after it has turned on. Is the connection between J111 on the DC controller PCB and J204 on the composite power PCB good? Is the connection of the connector J208 on the composite power supply PCB normal? Check the 24-VDC line between J111 and J204. Is its continuity good? Is there an output of 24 VDC at the J111-1 and J111-3 on the DC controller PCB
Mar 16, 2010 | Canon imageRUNNER 400S Copier
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
E-000003-0000
During printing, the main thermistor detects less than 120°C/248°F for 1
sec or more continuously.
Main cause:
The fixing film unit is faulty (main thermistor fault, thermal fuse blow, fix-
ing heater fault).
Or the power supply PCB is faulty.
Or the DC controller PCB is faulty.
Action1.
Malfunction
Turn off the power; wait for 10 min, and turn on the power. Is the problem
corrected?
YES:End.
2.Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO:Correct the wiring.
3.Fixing film unit
Try replacing the fixing film unit.
YES:End.
4.Power supply PCB, DC controller PCB
Try replacing the power supply PCB. Is the problem corrected?
YES:End.
NO:Replace the DC controller PCB
Nov 07, 2009 | Canon imageCLASS D320 Digital Copier
Wont power up
Helo,
If the power supply from your friends old computer may not fave all of the correct plugs to power up your computer. You system needs 2 plugs going to the motherboard one with 20 pins and one with 4 pins. Besure you have the correct plugs. The second thing to check is recheck the friendss power supply in another machine. Last option is that when your power supply overheated and died that it damaged your motherboard and you may have to replace it too.
Buddy
Corporate Computer
Over 21 years of PC and printer support/service
Jun 18, 2009 | E-Machines eMachines Desktop PC
XBOX 360 power brick flashing orange and green
according to the microsoft website:
The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply itself. The power supply can turn itself off when there is too much current, too much voltage, or too high a temperature. Under these conditions, the light on the power supply will turn from green to orange or to red. Or, the light will turn off. When the power supply light is green, the power supply is working correctly.
To help the power supply work correctly, always try to use the following best practices:
  • Make sure that all ventilation openings in the power supply are free to ventilate.
  • Do not put the power supply on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Plug the power supply directly into a wall outlet. In other words, do not use extension cords or power strips.
Basically, feel if it is overheated. if it is let it cool down. If not try a different wall socket. If that doesn't work you probably have a problem with your power brick or console. Try borrowing someone else's power cords.
Jun 15, 2009 | Microsoft Xbox 360 Console
Hotpoint Aquarius WMA42 Front Load Washer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
