Question about Toshiba (P000284020) Motherboard
Whater went inside of toshiba laptop
Was functioning for a little more,after the nework card was not any more recognized,after starts to shut down by itself.
please tell me if there is anyy chance to be fixed.
thanks,and regards
    Scholar:
  • 45 Answers
Hello ianacasta2,
Yes it may be able to be fixed.... but you will have to see what happens after you do the following:
First go get some isopropranol.
Simply remove the motherboard (and remove ALL the bits from the motherboard) then fill a small bowl with the Isopropranol and place the board in it and swill the liquid about it for 10 mins.
Leave it over an hour and then take out of the isopropranol and dab it dry with an absorbent cloth (DONT RUB). then place the board in a warm area for 2 days to air dry.
When it is dry, rebuild the board and put the network card in a different slot....in other words.... if your network card is in slot 2 now, then when you rebuild the board put the card in slot 3. ok?
Now, IF its all ok when you switch back on.... great.... problem solved!
If not, then you may need to go and buy:
A new network card.
A new CPU
A new stick of RAM
A new Hard Drive
A new motherboard.
I cant say which you will need as I cant see the board, but if the above does not work it sounds like you have a problem with one of them. DONT WORRY because if you take your computer in to a good computer store that will be able to check for your the components I have listed and will be able to narrow down the fault so that you may not need to spend lots of money buying components to replace everything.
Good Luck.
Posted on Nov 28, 2008
My toshiba laptop was recently swiped clean and rebooted running vista. Everything was running smooth.until i shut down the system. the next time at start up it didn't recognize any OS. the next t
I recommend reinstalling Vista, and replacing the Hard Drive as well. The errors being sporadic could be indicative of a hardware failure or a software failure and could be both in tandem.
Dec 09, 2012 | Toshiba Computers & Internet
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters Electronics module
Aug 16, 2012 | HP DesignJet 500 InkJet Printer
New Toshiba 17" functions properly until it has
Hate to be the bearer of bad news but it sounds like the graphics card inside the machine is over heating , i would check that all vents on the laptop are clear and unblocked , but if you have used this continually in this state then i doubt you will be able to repair it, as heating it up and then letting it cool down all the time will have done it no favours at all. The graphics gpu cannot be replaced so if cleaning the vents makes no significant impact then your laptop will need to be replaced
Mar 10, 2011 | Toshiba Satellite P205-S6287 Notebook PC
Trying to download music to a microsd card and i dont know how to open
Leave the SD card plugged in the computer and shut it down. Remove the SD card and boot the computer back up, then insert the SD Card to see if Windows recognizes it has files on it.
Sep 17, 2010 | Toshiba Computers & Internet
I have a Toshiba Satellite T1300, the computers starts fine but the video screen is black.
Try to hook it up to an external monitor, if this works,your video card is working, Next Step.. then look on the laptop keyboard for a functiion key with a little picture of a screen on it, usually u have to hold down the fn key and hit F4, or F5 or F6 etc, look at the F keys at the top of the keyboard, and hold down function key at the bottom left of the keyboard, usually near the alt and ctrl keys, if you dont have a fn key (function key then hit ctr key, and at the same time hit the F key with screen pic on it, it might say lcd on key or be a box inside a box on the key. If this doesnt work try rebooting the laptop in safe mode by hitting F8 key before windows starts and go into safe mode. It is possible that a recent program or windows update that was installed is causing the blank screen. If the black screen happened after a new software install, delete that software while in safe mode. And reboot, Good Luck :)
Mar 31, 2010 | Toshiba Satellite PSPA0U01S006 Notebook
Misc card stuck in slot, how do i get it out ?
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Jan 31, 2010 | Toshiba Satellite Pro A210-EZ2203X...
I was shutting down my toshiba laptop, its now frozen.
If nothing else works remove the battery, leave it for 5 mins then replace it and it will start as normal. Yyou will get an error message usually saying it was not shut down correctly and it may do a system scan but unless there is a real problem with it that will restart it. Ive had to do that twice with mine in the last year.
Jun 15, 2009 | Toshiba Satellite A135-S4427 Notebook
When powering up I get 2 short beeps and one long one.
The beep code is signifying either improperly seated/ bad ram or improperly seated/ bad video card. Since you replaced the RAM I would say it would be a bad video card. Replace & reboot. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Toshiba Tecra S1 Notebook
Toshiba (P000284020) Motherboard Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
