Question about IBM ThinkPad T43 Notebook
IBM T43 laptop will stop running after one minute of turning it
On. I have to hold down the top right click button for it to start running again?
  • Anonymous Dec 16, 2008
    no power 5v always on ic max 1901e
T43 screen dims and laptop will not shut down
The screen will dim on battery power to save energy. The power settings, found when you right click the power icon in taskbar notification area and go to power options, can be changed to your personal preferences. The shut down issue may be what is running, I can't say what is running, but look at the Start up process in MSCONFIG and shut down what is not necessary at Start UP. Look at tutorials on Faster Start up and Shut down. There may be many items you can shut down/disable to speed up these events. QUESTION: Is this a upgrade to WIN 7 Ultimate, If so your computer me be a bit short on specs, in other words you have reached the computers hardware limits. How much RAM, CPU speed...etc.
Nov 05, 2012 | IBM ThinkPad T30 2366 Notebook
Wireless and Bluetooth not working running on ubuntu
Instructions
Close any open programs and files. Click "Start," "Run."
Enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Open:" box.
If your IBM T43 is running Windows Vista or 7, enter "C:\DRIVERS\WIN\WLLANATH\SETUP.EXE" in the "Start Search" box.
http://www.thinkwiki.org/wiki/How_to_setup_Bluetooth
Press the "Enter" key on your computer's keyboard. The Wireless LAN setup wizard will appear.
Follow the onscreen prompts to complete the Wireless LAN installation. You will be prompted when the process is complete.
5
Click "Start," "Turn Off Computer," then "Restart" to restart your computer when the Wireless LAN setup process is complete.
Tips & Warnings
If you haven't already downloaded the Wireless LAN utility to your T43 laptop, click on the "Wireless & Networking Accessories - ThinkPad T43/p" link in the Resources section. Then click on the "ThinkPad 802.11abg wireless Lan Mini PCI Adapter II" link to download the Wireless LAN utility.
Jun 07, 2012 | IBM ThinkPad T43 Notebook
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Sep 09, 2011 | Computers & Internet
I need download bluetooth
You can find Bluetooth drivers for this laptop on this page. Click "Communications - Bluetooth" at the top and you'll scroll right down to the driver you need. Good luck!
Mar 13, 2011 | IBM ThinkPad T43 Notebook
Laptop IBM T43 some of the keys are not typing alphabets only getting numerics.M,K,O<P<I are some of these
Hi. You need to turn the number-lock (NumLock) off. There should be a button on the keyboard to do this. If you find the button, hold down shift and press the NumLock button. If not,click - Start > All Programs > Accessories > Accessibility > On-Screen Keyboard, and click the NumLock button. This should solve your problem. Post back results and good luck.
Feb 24, 2011 | IBM ThinkPad T41 Notebook
I need to download AGP card Driver for IBM ThinkPad model T43 notebook
The video card drivers can be found on this page, just click VIDEO at the top, then chose the version of windows you are running and download it right there. Before you go though please accept this solution / rate my answer 4 thumbs up, it would be extremely helpful if you could do this for me. Thank you!
http://www-307.ibm.com/pc/support/site.wss/migr-58597.html
Oct 10, 2010 | IBM ThinkPad T43 Notebook
How do i turn my wireless on my laptop
front
Hope it helps !
Jul 14, 2010 | Advent Netbook
Ibm thinkpad laptop plugged in powers off after about 15 minutes
Have you checked the power settings in the BIOS set up? There are ways to automatically turn off machine there.
Dec 10, 2008 | IBM ThinkPad T43 Notebook
I have a IBM T43 latop and when I turn it on after about 1 minute it stops processing? If I hold down the top right click button it will start again?
is the system coming up to windows . desktop. please explain better. so that you can get a better solution to ur lappy
Nov 28, 2008 | Computers & Internet
IBM Thinkpad T43 Memory
ok listen listen the answer is this the other memory is right under the keyboard. turn the lappy upside down the screws that hold the keyboard in are the ones mark with two triangle then open the lappy like you would normally for operation use a screw driver flat head is good put it between the bottom left or right corner better yet put it in line withe the down arrow key push the keyboard up as though you are pushing the function key closerto the top then pluck up the keyboard gently as you would a tin of paint gently a cable is there that connect the keyboard to the motherboard disconnect install the memory then work the steps backward
Apr 14, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
120 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
