Question about Philips Brilliance 201B 21" CRT Monitor
Succesive degausinge and horisontal line-bugging
My Philips brilliance200b monitor has horisontal thin bug-lines - mostly at the middel and little above the middle of the sreen. Furthermore: Every 5-20 sec, it starts a degausing and resizeing of he visual screen. Both sympthoms appears in boot and after burn in (cold and hot electronics) I guees that, its some capasitors, that needs replacement, but I am not skilled, in detechting such bugs. Ought I just trash this monitor, or is it just a minor bug, that some electronic-guru will replace at low cost? Or it it possible that I could find and replace this component - that is: Is this problem a wellknown problem for monitors or Brilliance 201B in general? Thank you wery much. Thomas
  • Thomas Lund Madsen Jan 15, 2007
    Thank you for this excelent piece of advise.
    I see, that my question is does not specify, what I really need to know - so I try to be more specifific:
    Judged by the symptoms:
    1 Repeated, automatic Degausing
    2 Thin black horisontal middlescrren lines
    Is it possible that the highvoltage capacitors, and ore the wireing from tre CRT to these capacitor needs replacement?
    Furthermore:
    Ought I to clean the entire inside - with isopropyle alcohol?
    Thank you were much
    Thomas
    Problem Solver:
  • 18 Answers
If you do not have high voltage training, messing in a CRT based monitor can hurt you due to the high voltage risk. Detecting failed electrolytic caps is not hard. I've replaced the caps in my monitor a couple times (It's a 12 year old 21" CRT, that replaced a 10 year old 20" CRT 10 years ago), but you do need basic soldering skills. An electronics tech could probably fix this for the cost of a hand full of caps, but remember, you will need to pay for service time (skills are costly), and that will probably run 75 to 100 dollars. If you are concerned that someone may benefit from you lack of ability, then you can have the monitor diagnosed for $35.00 or so in most places, donate it to a charity that refurbishes computers for the needy, and let them fix it :), or just ride that bad boy until it dies (what I'm doing, I'm not replacing the caps a third time, I'm planing on getting a 24" widescreen LCD to replace my 21" CRT) Peace. P.D.
Posted on Jan 14, 2007
SOURCE:
Sinotec PHD-50HU31. First, thin line running vertically down the center of the screen. Now, only a 2cm wide horisontal line appears at the top of the screen. Rest of screen is black.
If you wish to get more details visit the site linked here. Line faults to many popular brand sets are given with illustrations. You can get an idea about the fault. http://electronicshelponline.blogspot.com/
Feb 10, 2017 | Televison & Video
My new mac pro laptop has broken lines coming from mouse pointer or cursor. stated 2 weeks ago. what does this mean?
Macs were having some issues with something like that happening after people used an external monitor.
Here is a link with more information. Bug Dotted line dragging along with the mouse pointer
Feb 24, 2015 | Apple MacBook Pro Notebook
Samsung plasma black line fix
Sustain board fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to Plasma screen are given with illustrations.
Aug 06, 2014 | Samsung Pn50a450 Pn50a450p1dxza 50" 720p...
Has a blue vertical line on middel of the screen.
please contact ur vendor it will cost u less then $3 to get it repaired
Apr 01, 2014 | Panasonic BT-LH1700W Monitor
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Brock
Sep 16, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
A thin blue line in the center of the screen Flat Tv
You have capacitors going bad in the monitors power supply. Take it to a reputable repair person or check my website www.micromendllc.com
Feb 26, 2010 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Thin Green line from top to bottom of screen
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
Jul 02, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Horisontal lines
make sure the cords are connected properly from both the computers end and the monitor
Feb 03, 2008 | BenQ FP931 (Silver, Black) (Black, Silver)...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Philips Brilliance 201B 21" CRT Monitor Logo
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
