Question about Minolta Di351 All-In-One Laser Printer
Minolta Di200f aborts start up when turned on
We have a Minolta Di200f which when turned off will often not start up again. About 4 seconds into the start up an abort screen shows up on the panel and the copier then trys to cycle through and start up again. Our local tech "thinks" it might be the power supply but doesn't know for sure. The following is the abort screen
Abort
code = 0x00900000
tskid = 0x00003e80
sp = 0x902191e0
ra = 0x9fd25f8c
build_0720.010614
Thank you
    Genius:
  • 3,422 Answers
HI,
This is what the error code means:
0x00900000 to
0x009fffff
MFBS Board, FAX Board, Memory Board*
Scanner control system
failure
Posted on Dec 06, 2008
  • Priya darshan Dec 06, 2008
    • When the system program is aborted, the copier attempts to restart it automatically. If it fails to restart the program, check the electrical component, unit, option, and connection relating to the specific type of the abort condition.
    0x00900000 to
    0x009fffff
    failure
STARTS TO PRINT,THEN STOPS AND CODE C1300 POPS UP.
print head is bad replace it if you can find one that is a legacy Minolta machine, Now Konica Minolta, try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2014 | Konica Minolta Di200 Di200f Di250 Di250f...
C3710 error code for Minolta color copier Di200f/di251f/di351f ?
First Sir/Mam, Please let me explain the Di 200f series is not a color copier! What is the model the code C-3710 is not associated with the Di200f series.
Aug 29, 2013 | Konica Minolta Minolta Dialta Di200f...
Need to turn off ecm for faxing
utility, meter count, stop00 stop01 FAX settings
Apr 01, 2013 | Minolta - DI200F Printer
I HAVE A MINOLTA Di200f/Di251f/Di351f ERROR CODE CO500
First check the right side cover where the image unit is located. Check the two latches that latch the door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jun 23, 2011 | Minolta - DI200F Printer
Cant get my minolta di200f attached to my new windows 7 pc. What driver to use?
NOT going to happen best would be 2000 xp 95. Try this web site direct from konicaminolta. your machine is a legacy Minolta Machine
Self Help Product Support Konica Minolta Business Solutions Inc
Jan 28, 2011 | Minolta - DI200F Printer
I have a C0500 error on my Minolta Di200f and from what I've read, I need to reset the machine, but I don't know how.
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
For fuser try this site
Oct 13, 2009 | Minolta - DI200F Printer
Error when turning on machine.
I have a feeling that this has something to do with software on the hard drive. Either the software needs to be restored on it or it could have crashed. A Konica/Minolta dealer in your area should be contacted to send a technician out to look at the situation.
Aug 08, 2008 | Minolta bizhub 200 Copier
Minolta Di200
I need the default password for my copier its. Dialta Di 200
Dec 30, 2006 | Minolta - DI200F Printer
Minolta Di351 All-In-One Laser Printer Logo
137 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
