Question about Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100)
Hi there I was wondering if anyone could help me with a connection problem. the problem is my motorola cable modem will not go online all lights light up appart from the online one which only flashes. any help would be highly appreciated. regards michael
  • 1,879 Answers
Use reset button at the back.
if it is purchased - got to contact ISP to register the MAC address.
if it is provided by the ISP - have it replaced.
Posted on Nov 28, 2008
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Motorola sb4200 no internet Acess Issue
i click the status and is say Transfer Operational Parameters through TFTPIn Progress
Aug 19, 2012 | Arris SURFboard SB4200 Modem
Sb5100 surfboard motorola modem I can't get an Internet connection on my laptop. The only light lit on the modem is standby. I tried unplugging it to reset it but it didn't work. Please help!
the standy by feature is a button on the top of the modem. Press button and check that all your lights come on green (power send recieve and online). then you should have connection
Jan 09, 2011 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My Motorola sb5101 won't come online how do I troubleshoot this? My cable connection is fine. When the modem boots up the green power light comes on and stays on followed by the receive light and the send...
These modems are very tricky. When this type modem goes into stand by modem that indicates that you do have a connection to your internet service provider. The reason you cant get online is because all internet access is disabled wile the modem is in standby. If you look closely there is a button located on the top of the modem. This is the stand by button. If you hit that button it should take the modem out of stand by mode and reestablish your connection to the internet.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 02, 2010 | Arris SURFboard SB5101 Cable Modem
My modem keeps going to standby mode
That is usually a problem with signal levels or the modem isn't set properlly. I don't know who your provider is but you should get hold of them and get them to fix it. They should send a tech out to check your signal. While they can check the modem remotely it does not provide them with the same information that a onsite check does. There is nothing you can check or change as a end user.
This can be signal levels, or signal quality (noise), or bad cableing and so on.
Apr 16, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Power, Receive, Send flashes, No online light or the rest. Help?
Throw it away or send it to Motorola they get very HOT and this causes failure its common in routers and modems
Sep 21, 2009 | Arris SURFboard SB4200 Modem
Cannot go to internet
As stated on your previous post asking this question:
"If the "Online" indicator is not on, then the modem does not have an internet connection. The only thing you can do is unplug the modem for 15 seconds and plug it back in. Wait 30 seconds for it to cycle and the lights should all come back...if the "Online" light still does not go on, then you need to contact your internet service provider."
There is really nothing else you can do!
May 05, 2009 | Arris 4 ft. Modem Cable (40384)
Cable modem connection problem
Hi, First of all that particular modem is an End of Life modem (meaning it is no longer recieving updated firmware). But that still does not neccesarily mean that its your modem what you need to do when your modem cuts out is to note the leds on the front of your modem. If the modem gets stuck on either the 2nd light from the top or the third light then it is definitely a cable problem. Contact your cable co and tell the tech what lights were stuck blinking while you could not get online and he will know what that means. If you need some more help let me know, because I can explain more. good luck
Dec 31, 2008 | Arris SURFboard SB4200 Modem
ONLINE light is off, power, receive and send are on.
Online Flashing - Scanning for a network connection.
On - Startup process complete. Modem aqcuired.
No online means no connection to the cable company DHCP server
Aug 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
MOTOROLA SB5100
This means that your modem is not locked onto your cable providers network
Jun 21, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Arris SB5100 SURFboard DOCSIS 2.0 Cable Modem (50120900100) Logo
260 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
