Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore ultrabake lights up when stove top is on but wont heat up
We had side dishes in the warming draw rolls cooking in the oven,when it stopped working . the pre heat and time will come on as soon as i turn stove top on but nothing heats up.stove top or oven and as soon as i turn the knob to off screen goes blank
any clue what is going on
thanks
kelly
  • Anonymous Dec 21, 2008
    I have the same problem it heats up but does not stay. Temperature still reads 375 however you can touch everything within the oven and you will not get burned. I had it serviced and still a problem. Does anyone know if this stove has been recalled. I Have an Ultrabake Gas range only purchased 5 years ago.
  • 833 Answers
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Posted on Nov 28, 2008
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
My kenmore 790 oven will not lite is there a pilot light?
if you have no bake most likely you need to change out the ignitor,next time send the model number,if it's a stove with the burners on top open the utility draw and on the left or right side on the frame you'll see the model number
Oct 17, 2010 | Kenmore Ovens
My stove works but it wont stop beeping
My scholtes cook top tig 664 won't stop beeping... Coming close to using a hammer! Help!
Oct 04, 2010 | Kenmore Ovens
Kenmore stove model# 665.92024100 While cooking
Check and see if the broil element has shorted to ground.
Bonus
Apr 13, 2010 | Kenmore Ovens
Oven not working!
we're having the same problem.lol
Apr 10, 2009 | Kenmore Ovens
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
Kenmore self cleaning oven model 790.9520 : element stays on
sounds like it was in the preheat mode the cent to the cook mode so you can cook
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
185 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
