Question about CTX P772 17" LCD Monitor
The image on the screen has shifted down slightly and to the right approximately 1/4 of the entire screen (about 3"). I've tried to adjust the settings using the controls on the bottom of the monitor, but have been unsuccessful. Any help is appreciated. Thanks.
    Problem Solver:
  • 19 Answers
Right click to your desktop and go to graphics option.
Posted on Dec 17, 2008
  • Melbert Daiz
    Melbert Daiz Dec 17, 2008
    right click your desktop and go to graphic options. and also check your display properties you might set it with the different resolution to your monitor.
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
Have a 4 yr old 32" samsung flat screen. The screen recently has an approximately 1/4 inch wide line going horizontally across the entire screen and more recently a second line of approximately 1/3 of...
It can be costly and difficult to replace the internals of any flatscreen television screen. Your best bet is to consult an electronics professional in your area for an estimate in repairs.
If you are a technically inclined person and you've got nothing to lose, you could always try ordering a new board online and attempting an install on your own.
Take a look at NewEgg, they usually have a good deal now and again on electronics parts, televisions included.
http://www.newegg.com/
Jun 14, 2011 | Samsung LN32C530 32 in. TV
How do you adjust a headlight from pointing up to the right height
VERTICAL AIM ADJUSTMENT
1. Park the vehicle on a level surface approximately 7.6 meters (25 feet)
from a vertical wall or screen directly in front of it.
2. Measure the height from the
center of your headlamp to the
ground and mark a 2.4 meter (8
foot) horizontal reference line on
the vertical wall or screen at this
height (a piece of masking tape
works well). The center of the lamp
is marked by a 3.0 mm circle on the
headlamp lens.
3. Turn on the low beam headlamps to illuminate the wall or screen and
open the hood.
4. On the wall or screen you will
observe a light pattern with a
distinct horizontal edge of high
intensity light with a slight angle
towards the right. If this edge is not
at the horizontal reference line, the
beam will need to be adjusted.
5. Locate the vertical adjuster on
each headlamp, then use a 4 mm
socket/wrench to turn the adjuster
either counterclockwise (to adjust
down) or clockwise (to adjust up)
aligning the upper edge of the light
pattern up to the horizontal line
6. HORIZONTAL AIM IS NOT
REQUIRED FOR THIS VEHICLE
AND IS NON-ADJUSTABLE.
Mar 09, 2010 | 2002 Ford Explorer
The problem I am having is that my 32' Sony Wega kv32fs12 Trinitron television will work almost perfectly. Image color is beautiful. tuners seem to be working like a charm, but the screen has a slight...
Picture alignments made in servive menu.
pwr off + display + 5 + (+vol) + pwr on
You must do all within 1 second.
1&4 move thru settings, 6&3 chg value,
muting & enter saves chgs.
Your code access could differ.
In the menu note down all existing settings.
Make small adjustments and watch what happens if not in right direction reset that particular option to original value before you changed. In those menus you can bend, shift hor. and vert., etc.
But be warned only slight adjustments and write down start values before experimenting. Or you can get in to serious trouble.
Good secret service menues keep an access counter for manufacturer/dealer to see how many times it was used.
May 04, 2009 | Sony KV-32FS12 32" TV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Entire image shifted
Press the Select/Auto button. The monitor will then automatically adjust to match the incoming signal and will save that setting in the internal memory of the monitor.
Nov 06, 2008 | Hyundai L90D+ 19" LCD Monitor
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
CTX P772 17" LCD Monitor Logo
48 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
