Question about HP Office Equipment & Supplies
The printer will not pick up a sheet of paper when I try to print. I get the message that there is no paper even though there is.
  • 51 Answers
What printer do you have?
This problem is caused by "used" pickup rollers, that are the rubber rollers that pickup up the paper. As they cannot pick the paper, you get the message that there is not paper.
You may clean the rollers using a clean cloth with a litlle of alcohol and it should solve your problem.
Posted on Nov 28, 2008
My Polaroid z300 stopped printing pictures and keeps telling me to load it even though there's paper inside. How can I get it to print again?
It could be that the paper supply sensor isn't properly activated, or a new sheet isn't being picked up. Try removing all sheets of paper and inspecting with a flashlight.
I once assisted a frustrated elderly friend with a similar situation, and discovered that a white kleenex tissue had found its way into the paper loading mechanism! Her initial inspection had not detected it because it was camouflaged!
On another occasion, the rubber feed rollers didn't have enough friction to pick up a sheet of paper until they were cleaned with rubbing alcohol.
Dec 25, 2014 | Office Equipment & Supplies
My HP 2600n printer always jams if there is more than one sheet in the paper tray. If there is only one sheet in the tray, it never jams but if there is more than one sheet, the first prints and while its...
Hello ,
The pad of solinoied become teared & only gum left on solenoied by which on the paper picking proces it fix on the base,by which the picking rooler continious mooves & pick another paper & become jam.so clean that path & remove the gum & paste the tape .your problem will be resolved 100%.
jm
Sep 07, 2011 | HP Color LaserJet 2600n Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP Office jet Pro L7380 will not pick up paper
Paper feed problems are very common with HP officejet printers but don't panic...
Few things to try..
1. Check that when the printer tries to feed paper the wheel is dropping down and making contact with the paper.
2. Make sure you have not set the paper guides so the paper is too tightly held... try loosening them
3. Watch this little video on how to fan-apart paper and try doing this to get some air in between the paper sheets.. This often resolves many of the problems.
4. Try changing the paper for something a bit coarser or even cheaper as HP printers can be a bit "Fussy" about the paper they will feed best...
Hope that helps...
Mar 12, 2009 | HP Officejet Pro L7380 Laser Printer
Pulled out paper & broke the printer
There is a part of the printer that looks like a roller (sorry I can't remember the name now) but you may know it. It rolls over the papers to pick one at a time and forward that to the printing segment. If you can reach it, try (gently) to adjust it into place (or normal position). It probably rotated half cycle or so when you forced the paper out. It needs to complete the cycle in order to tell that there is paper. I am using experience from laser printers so bear with me. But that's what usually causes such problems after **** occassions.
May 09, 2008 | Canon MX700 Office All-In-One InkJet...
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
70 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
