Question about Honeywell Heating & Cooling
Hi my oil furnace keeps comming on every 10min the system is 1 year old and i just installed a new homeywell thermostat and set the gauge at 50 and the temp. is 80 that is way to hot in here.
  • 61 Answers
Cut the unit off it sounds like it is tripping on high limit this could be dangerous.
Take the wires off of your primary control and see if this stops the furnace. the wires should be marked t and t Post me back with details
Posted on Nov 28, 2008
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
My 23 year old Rheem furnace stopped working not long after installing a programmable thermostat. Is the thermostat the problem or the unit is just too old?
If you did not turn off the power to the furnace when you installed the new thermostat. There is a very good chance that you shorted the thermostat wires and burned up the transformer in the furnace. Or, if you're lucky, you may have just blown the control voltage fuse if there is one installed.
Oct 29, 2009 | Heating & Cooling
My honey well thermostat keep clicking and I can't program it
If you have a programmable thermostat and it is a couple of years old you will probably have to install a new one. What kind of thermostat do you have? You can turn power off to furnace and then take thermostat off wall and take wires marked r & w and connect them together your heat should come on when you turn power back on. If not you could have blown the 5 amp fuse inside furnace. I would check the fuse inside of furnace. If you take panels off front of furnace you should find a controll board inside that runs furnace.If you have anymore question just reply back to me
Jan 07, 2009 | Honeywell Programmable Thermostat Heater
New thermostat honeywell RTH7400 cycles oil furnace every 10 min.
rth7400 maintains a 1 degree differential in temp so 10 minute cycles are not unusual.
Vinnie
Jan 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
