Question about Maytag MSD2756GES Side by Side Refrigerator
Water puddle under fridge
I have this maytag model msd2756ges side by side. In the past seveal days i have found a small puddle of water under the front part of the fridge. Can someone tell me what the problem is so i can know how to go about fixing it....................thank you
  • hotrodruss Nov 28, 2008
    I had a feeling it may be a blocked tube or something like that. This fridge is 6 years old. Had defrost problems exactly one year ago. Saw the applaince repair guy take the panel out and defrost with hair dryer. When that problem happened it turned out to be an issue with the electronic board that controls the defrost operation which is located in the frige part. I will do as suggested for this issue and hope that this will be a one time fix and not have to do this again................thanks for the help.
  • christoph37 May 02, 2009
    I've also been experiencing the same problems with my MSD2756GES
    - excessive ice build-up on the bottom of the freezer to the point
    where the bottom basket is frozen in place. From time to time, the
    refrig. seems like it's trying to correct the problem, some of the ice
    melts out through the door gasket and onto the floor with no real
    improvement - ice continues to build-up. To make matters worse, I just
    received a letter from Maytag stating that my refrigerator model is
    part of a recall of 1.6million refrigerators due to possible
    overheating of compressor causing fire. Maytag has contracted an
    authorized repair agent to visit my home in a week to make recall
    repairs. Have experienced nothing but problems with the refrig. since I
    purchased my home 18 months ago. Also experiencing problems with
    buttons that select between crushed ice and cubed ice and lighting
    inside refrig. Maytag claims no responsibility as I've tried to get
    them to be responsible for problems. Any help/direction would be
    appreciated...
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Nov 28, 2008
I have the same model and the drain was plugged from day one, I had to force the drain open by sticking a thin wire down the drain hole, 4 years later and I'm having issues with the defrost mechanism. I would like to reapir by myself if I can figure out how to get the panel over the temp controls off the top of the fridge and what the part is
Posted on Jun 27, 2009
Could i get the scamatics or diagram
MSD2756GES MAYTAG SIDE-BY-SIDE REFRIGERATOR ...
www.searspartsdirect.com > Kitchen Appliance Parts > Maytag Parts
Download Manual for Model MSD2756GES MAYTAG SIDE-BY-SIDE REFRIGERATOR.Sears PartsDirect has parts, manuals & part diagrams for all types of ...
Sep 22, 2015 | Maytag MSD2756GES Side by Side...
Why do I have a puddle under my fridge every couple days but no sign of a drip or leak?
If it is an automatic defrost fridge the it will have a hose draining down into a container under the fridge, make sure it is draining where it should and has,not become dislodged. Some have a small tray with either pipes inside it or an electric heater. Some have a container sitting on top of the compressor, both of these are used to evaporate the water.
check to make sure there are no holes in the water catcher.
if you have an electric heater that is not functioning then the container will be already full of water and at each defrost cycle will overflow onto the floor.
Sep 08, 2014 | Refrigerators
I( find a puddle of water on floor at front left hand corner on freezer side..I took the freezer drawer out and found ice build up under it ,could this cause my problem.. this happened about every 24 hours...
The problem with your refrigertor is that the defrost drain is plugged up. After you get the ice buildup out of the freezer section you will have to locate the drain system. It is in the back of the freezer at the very bottom.It needs to be cleaned out. Hope this at least leads you in the right direction.
May 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Refrigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 20, 2008 | Maytag MSD2756GES Side by Side...
Maytag
Heres you problem your drain plug in freezer is likely frozen as well and water is running under fridge. You have to replace the thermostat defroster assembly Its behind the panel at rear of freezer and runs down and under condenser coils. Part cost $42 and plugs in its easy to replace It creates heat which keeps the coils free of ice and also keeps drain from freezing.
Jun 19, 2008 | Maytag MSD2756GES Side by Side...
Maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Aug 31, 2007 | Maytag MSD2756GES Side by Side...
Maytag MSD2756GES Side by Side Refrigerator Logo
2,424 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
