Question about Canon MF8180C Color Laser MFC Printer
Finding the reason and solving the problem
Sir, I am a beginner and also small investor. i have recently started my xerox unit, having two caon imagerunner. often i have a problem of error codes i could not run my business peoperly and regularly.
How can i find the solution for this problem. i know noting about the machines.
  • 1,219 Answers
You must be informed and know want you want... so get some brochures, error code details,...
Posted on Jan 12, 2010
Respected sir my ir400 canon xerox mashin masage is switch main power off and on.e001 i have machin switch main power off and on but problem not a solve pls discription this probem and solve. thanking...
it is related to fing unit.
you can go in service mode by pressing (additional function +2 +8 + additional finction)
touch on copier then go in function after that touch on clear
Err -then press ok
dcon then press ok
rcon then press ok
if then after problem not solved you have to replace fixing unit thermistar
because it is related to fixing temperature.
Apr 12, 2011 | Office Equipment & Supplies
I just received a Xerox 5334 copier. We moved it to our house, powered it up, and ran a test copy (just a sidebar thought...it spit out one copy and a blank paper). I left it on to go retrieve the work I...
Code U4-1 is Over heat or under heat, even if you solve this problem you mentioned that you have a copy from the machine which is Blank, the reason is that the print cartridge is dead, it is not holding charge, and even if you find a new one in a box sealed, I am 99.9 present sure that it is not going to work either, it is an old expired cartridge, basically do not waist your time and money, I serviced these machines and I know.
Mar 23, 2017 | Xerox Office Equipment & Supplies
Xerox Phaser 8860 says "Maintainance Kit is Missing"
Most likely it needs service. Here is the service provider finder from Xerox.
Aug 24, 2009 | Xerox Phaser 8500/DN Printer
Why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
Jun 06, 2009 | Xerox DocuPrint C525A Laser Printer
Xerox wkctr 35 toner fault 9-567
Hi sir; Just need to replace toner sensor should be take care your problem, if you solved the problem ,don't forget to give me a rating, thank you !
Feb 27, 2009 | Xerox Office Equipment & Supplies
I Have recently downloaded Hubb Investor ver2 and have received my Hubb investor serial number but cannot find any programm relating to charts for which it acceptable.The serial number is2302-483-9046-8485
Thank you for your interest and offer of assistance.I have solved the problem it was simply a matter of being able to establish the correct address from a substantial array of alternatives
Nov 08, 2008 | Computers & Internet
Error code 9-343 for Ducocolor 12
That is a contact failure on the BTR roller. It is the larger black roller inside the left side door. It may just have a dirty contact, or may need to be replaced. But for some reason the machine is not seeing good contact to that roller.
Mar 21, 2008 | Xerox DocuColor 12 Printer
Canon MF8180C Color Laser MFC Printer Logo
48 people viewed this question
old marine
old marine
