Question about Dishwashers
No power to dishwasher
All of a sudden there isn't any power to the dishwasher. No lights, nothing...please help Maytag dishwasher Model # MDBH965AWW. Two years old. will not turn on. Control buttons will not funtion. Help
  • JEFF SIEGEL May 11, 2010
    You will need a voltmeter to figure this out. Let me know when you are ready.
  • 338 Answers
Start by checking for loose or melted wires under the dishwasher underneath in the "junction box". if the wires arent melted and the plice is ok. then you may need to look for the thermal fuse by the control board. make sure your breaker isnt tripped. go and turn it all the way off then back on.
Posted on Nov 29, 2008
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
Blinking "Normal" light on a Maytag model
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
May 19, 2011 | Maytag Dishwasher
Dishwasher not cleaning well.
Hi irfgnsheryar,
Please find a helpful hint on this problem here:
Hope this helps :-)
If it does, please vote accordingly.
May 10, 2011 | Maytag 24 in. MDB6100A Built-in Dishwasher
Hello- This series MDB7130 is involved in a recall. Check Maytag website for details. If affected, they will offer 75$ toward a new maytag.... or a free service call to 'retrofit' a new wiring harness. These units have caused a number of  fires so disconnect power until issue is resolved.- Let me know if this info helps. Thanks- Ed
Mar 12, 2010 | Maytag MDB7130 Dishwasher
My Maytag dishwasher Model # MDB-3 will not drain. Please help. Thanks! Anna Giacobbe
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
I just had a similar problem with a GE Triton. Suddenly the lights on control panel went wacky and it wouldn't start. I don't know if this will help you but try disconnecting the power source and wait a bit (this involved turning off the circuit breaker to d/w in circuit box). It cleared up the problem with the control panel and d/w just finished a good cycle. Hope this helps you. It was Step #1 on another site and they said there that this will allow the "computer" to re-set.
Good luck.
Dec 29, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
Jan 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Apr 13, 2007 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishwashers Logo
230 people viewed this question
Top Dishwashers Experts
