Question about D-Link Computers & Internet
Signal problem the problem is that my laptop connects to wirelessly, but comcast cable installed a wireless modem to my desktop computer and it will not connect to the router ( d-link 524 )
    Genius:
  • 1,913 Answers
Access your router settings then go toadvanced then allow your mec addreses in allow list.then save settings then restart the router.
type in run :ipconfig /all" to get mec adreses.
Posted on Nov 28, 2008
Adding to discription.I'm trying to connect two computers that access the net wirelessly but are not networked. I'm installing the HP using the HP installation disk,it does the configuration tells me to...
I am assuming your router or modem has wireless capabilities, or you have a wireless hub. If your provider is comcast you have to have comcast wireless equipment.
Make sure wireless is turned ON at modem/router switch and or IP page(192.168.0.1 in URL. most equipment uses that address by default if not you will have to get the address from the manufacturer of your equipment.). Again if your provider is comcast call comcast to set up your equipment (you have already paid for it!).Once you have established you are broadcasting a signal you should have no problem connecting. I hope that I helped GOOD LUCK
Sep 22, 2013 | D-Link Computers & Internet
Computer Will Not Power Up
I don't quite follow your question? My mergers? My wireless things? If you are referring to laptops/Desktops, connect a Ethernet Cable directly to the Comcast Modem. You can call Comcast to verify the signal and sent a fix signal, basically a reboot, which you can do by removing ALL power from the modem and wireless and replace battery, plug in the Modem, wait for selftest, plug in the wireless device, wait for selftest, try again. As to the Computer not powering up, that's another issue.
May 10, 2013 | Computers & Internet
I have comcast cable and internet but my cords wont reach to where my computer is, I also have a wireless linksys adater on my hard drive. Am I able to connect to my comcast modem with this?
That depends on what comcast modem you have. If it has an integrated router, yes. If it is just a modem not. Simply spoken, a modem just converts your computer's digital signal to whatever is on the other side, usually analog. It doesn't do what a router does - routing the signal.
Just reply to this post and let me know what model of modem you have and I can give you a definite answer.
Jan 07, 2013 | Linksys Wireless-G WMP54G 802.11g/b
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless Connection
It's possible that you are not yet connected to the wireless network that you have at home.
May I know the model no. of your wireless router from Linksys?
What is the operating system of your laptop?
You might also want to check if your computer is picking up the signal braodcasted by the linksys router.
May 19, 2008 | Linkskey Computers & Internet
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
