My computer fan is running continuously, from the time it turns on. (even before booting in to windows xp)
    Genius:
  • 1,250 Answers
Is it causing a problem and what the status if system shuts down
Posted on Nov 28, 2008
How to get to safe modem?
Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I've installed windows xp SP2. 1st windows was succesfully formated and copying windows, then windows booting, and this massage appear "Press any key to boot from CD/DVD"... then i let it...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jun 03, 2011 | MSI PM8M-V Motherboard
Computer won't boot when connected to DGM LCD monitor.
I have the same problem. Did you find a solution ?
Dec 28, 2009 | Computers & Internet
Black screen on monitor
do you have your original windows software disk?
you can go to safe mode by pressing f8 during the boot sequence.. tap f8 a few times from the second the computer starts to boot.
It is possible you have a virus or something that damaged the master boot record.
Here is a tutorial on recovering the MBR:
To access this, I booted the system from a Windows XP CD, waited for files to be loaded into memory, then selected R for recovery console, selected my Windows XP installation and entered the administrator password.
Once inside the Windows XP recovery console, I tried the fixboot command. This didn’t seem to make any difference on reboot, so I tried again with fixmbr. After another reboot, Windows XP was up and running (some Internet sites suggest fdisk /mbr but that’s not a recovery console command under Windows XP).
May 31, 2009 | Computers & Internet
My computer fan is running continuously, from the time it turns on. (even before booting in to windows xp) why does my hard drive fan kicks in all the time - its loud and annoying
The fans in most desktops do run whenever the unit is on. Only high end/ performance/ or self built systems usually have self adjustable fan speeds.
Mar 12, 2009 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
HP Desktop PC, won't boot even under safe mode
if the system was able to enter the desktop and restarts...once possible cause is a virus...scan the pc via safemode or reinstall windows.
but if it didn't enter the OS desktop...cause might be the boot loader or MBR is damage..
worth a try:
Run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. At the command prompt, type this commands one at a time.
FIXMBR C:
FIXBOOT C:
COPY [CDDRIVE]:\I386\NTLDR C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM C:\
BOOTCFG /rebuild
6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Feb 17, 2009 | Compaq (261671-001) Motherboard
Computer crash and restart
Windows restarts without warning
Cause:
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Jan 28, 2009 | Computers & Internet
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Instantaneous shutdown with no warnings!
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing. If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
Click Ok.
Computer virus
Heat related issue
Nov 19, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
