Question about Samsung HCL4715W 47" Rear Projection Television
My Samsung TV won't turn on. What is the problem?
Everytime i plug in my Samsung 47"TV, the screen wont go on and there is a click every 5 seconds or so with a constant chirping, almost like a bird. Is it an easy fix? and would I be able to try a few things out before having to spend $1000 on a new one. Model: HCL4715W, 1080i, 480p
  • 1 more comment
  • Andrew Hawkins
    Andrew Hawkins Jan 29, 2009
    I have the same problem. I have a formal electronics background but I don't have any schematics. Thus far I've just been searching the power supply for shorts with out success. If you are familiar with this TV, could you point me in the right direction? Thanks
  • Anonymous Apr 14, 2009
    somebody was messing with my remote trying to get all the functions of my two remotes onto one and now I can't turn on my tv
  • Anonymous Apr 17, 2009
    I have the exact same problem, with a little electrical burn smell!
The clicking is caused by bad capacitors on the mainboard. It is a known problem that is pretty easy to fix. I have never soldered before and I was able to fix it for about 6 bucks! If you take off the back cover (about 18 screws) the mainboard is right in the middle and in the top right corner are 4 capacitors. They are in a row from top on down. Check to see if any of them are bulged on top and if they are they are bad. All you have to do is go to radio shack and get 10u35 volt capacitors and solder them in to replace the bulged ones. The ones that came with the set are under powered and these will fix the problem. Most people are quoted about $500 or more to fix this when a little work on our own works wonders!! If anyone wants more info I am on facebook! Brian Miller in Wisconsin!
Posted on Apr 24, 2010
  • 1,139 Answers
Hello tom3826,
This is a sign that the horizontal output transistor has shorted to ground, and the shutdown circuit is detecting a high current event. If you have a background in electronics, you might be able to replace this component, with the aid of a multimeter, de-soldering tools and a schematic of the TV. If you do not have a background in electronics, I would suggest that you have a qualified TV technician work on your television set. The section in question is the Horizontal/High Voltage Power section.
I hope this helps,
Thank you,
Posted on Nov 28, 2008
I have a samsung HCL4715W the tech came out said that I needed a pcb assembly so I got one and still no change the tv does not respond at all no led on the front or anything what to do now aready in for just about $500.00 part was $230 instalation $100.40 $89 for the dynostics
Posted on Feb 12, 2009
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
Tv won't turn on light blinks on front
can u help my tv wont turn on samsung hcp4752w
Oct 25, 2011 | Samsung HC-P4752W 47" Rear Projection...
My television is a Samsung Slimfit tx-t2782 and I'm having problems with the tv staying on. Everytime I plug it in it comes on for a few seconds it shuts itself off. I was wondering if there is anything I...
I AM HAVING THE EXACT SAME PROBLEM WITH MINE ! But before mine turns off, it shows a blurry squiggly red mark on the screen then shuts off and wont turn back on sometimes for several hours.. And everytime I CAN get it back on, I have to unlpug the whole thing and plug it back in...
Nov 09, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Tv wont turn on, changed .5 amp fuse but nothing, its a 47 inch tevion lcd tv
hello have you check the fuse inside the tv glass type it will be in the power supply
Jun 14, 2010 | Televison & Video
My Samsung 47 has a black film covering 1/2 the screen for about
Samsung only makes TVs that last 2 years, mine also has the same problem. Throw it away and buy a cheaper disposable TV, despite all the hype Samsung is just another cheap and nasty manufacturer who uses its customers as product testers. Why do you think they keep changing model numbers every week ?
Jan 13, 2010 | Televison & Video
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Tv wont turn on
your power supply is bad and needs replaced
Oct 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv turned off
When the tv shuts done does the power light blink? If so what number does it blink? That will tell me which circuit your problem is in. Notice the number of blinks then let me know. Also what is the model number of your set.
Jan 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
5,490 people viewed this question
Jerry Greenberg
Jerry Greenberg
