Question about Dishwashers
I have an ariston lsi 45/50 which will not end it's wash cycle.i have checked the salt level,which is fine. Any ideas please?
    Genius:
  • 1,239 Answers
HI Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.,,,,,,,,,,,,,,,PLEASE RATE IT..........THANK U
Posted on Nov 28, 2008
2 of blinking lights near end of rinse cycle. Any ideas
Firstly I would check filter making sure it's clear then check salt level. You could also try unplugging machine for half hour and that might reset it.hope this helps you.
Jun 24, 2015 | Dishwashers
How to stop it frfom beeping/flashing 91 low salt.
1st... Check electrolytic cell and clean with vinegar...If white scalley stuff inside, cap one end and soak for 6 to 12 hrs and rinse until clean
2nd...check salt level, see manual for PPM, if low, add salt.. If you have a big pool 12000 to 15000 gallons, you will have to add up to 100 lbs of salt..
3rd... Run only pump for 24 hrs to dissolve salt..
4th... Set you cycle and should be fine
Hope this helps and rate if it does
Jul 16, 2011 | Intex Automatic Salt Water System for ...
I hear my water heater turning on and off during the cycle, but when I open up the dishwasher at the end of the cycle, the dishes are lukewarm, and sometimes there is still soap on them. This is...
it sounds as though the water level during the wash is too low to check put machine on let it run for 5mins then open the door once the water settles the level should be just below the salt cap no lower if it is then you have a pressure chamber problem water level is critical on these machines as the heater will not turn on till correct water level is reached.
Nov 01, 2010 | Bosch Integra 300 SHX33M05UC 24 in Builtin...
Ariston A1435 washing machine. The prgrammes do not move on.Can select any cycle it washes but stays on the programme and does not move onto the rinse cycle have to manually stop and select rinse and spin....
If the program is put ON does the inlet valve open to let water IN. If so does it after the water is filled to the set level go to wash If yes , then after wash does it drain ? If all the above cycle is true then the program is working correct and a fault in the input can be the reason.
If however there is distruption of the sequence, then each input and drive must be checked to establish if the program controller or the input sensors are faulty.
Please give me a feedback
Sep 18, 2010 | Washing Machines
We are having trouble finding salt to use in our Ariston LL 64 S stainless steel dishwasher - can someone please tell us what type of salt that we need to buy, and where we can find it? We live near...
Salt in the dishwasher or the water softener?
Did you check with the dishwasher manufacturer? Do you have an instruction book?
If a water softener, you use rock or sea salt available at your local Ace Hardware or other fine retailer in your area. If your dishwasher is making soft water for your machine, probably the same ... rock or sea salt.
Thanks for your question at FixYa.com
Jan 09, 2010 | Ariston Technologies LI640S Dishwasher
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston dishwasher
i have a brand new ariston ll-64 and the wash cycle won't start and two flashing lights
Feb 09, 2009 | Ariston Technologies L63 Free-Standing...
Dishwashers Logo
269 people viewed this question
Top Dishwashers Experts
