Question about Kenmore 73952 Gas Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
My 4 yr old dryer suddenly gave this problem. It runs only when I hold the START switcgh in hold position by keep it pressed with finger. is it START button problem?. Please suggest. I checked fuse, they seems to be good.
  • rao srinivas Jan 14, 2007
    thank you for the solution and quick reply
  • rao srinivas Feb 12, 2007
    I purchased the event control board from repairclinic and replaced the item. the old board has a burned out resister and capacitor. I still find the same problem. but I see some difference with part numbers you mentioned and what I see there on the repairclinic (http://www.repairclinic.com/0081.asp?Rcc... Are there any thing I can do to repair the problem.
    President:
  • 878 Answers
Psrao, right next to the timer under the consol is the even heat board. When this fails, it will cause this problem. This has been an issue with this model. Part number for the board is 3978949. Catriver..post back.
Posted on Jan 14, 2007
I have a 4 yr. old kenmore elite HE4 dryer. I put the clothes in and hit normal cycle. 41 minutes automatically comes on. I hit various buttons and nothing happens. I hit the start button and it finally...
if I am understanding the problem correctly then this website should work, if I am misunderstanding then the second one might help.
http://www.epinions.com/msg/show_~threads/cat_id_~17/id_~3088/forum_id_~409
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 03, 2010 | Kenmore Elite HE4 Electric Dryer
We have a kenmore elite oasis dryer.one year old.just bought from some people only had it for two days.it was in the middle of a cycle when it suddenly shut off with the code af appearing where the timer...
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis ST 6807 Dryer
Kenmore 90 series, 7 years old, no problems til now. all of a sudden, 3rd load of laundry of the day, press start button, nothing happens. There's power to the unit as the light goes on when the door...
That doesn't mean there's power to all parts of the dryer though. My Kenmore used to run but not heat & invariably a wire was burned through at the end - they get brittle after a while. I'd unplug the dryer - very important - open the back & look for a wiring problem. I could usually shorten the broken wire & make a good connection again. After years of patching it up we gave up we got a new dryer.
Nov 25, 2009 | Refrigerators
Kenmore dryer 500 electric, will not turn on, circuit breaker ok
Sounds like a broken belt or a faulty motor...
Sep 22, 2009 | Kenmore Dryers
Newer kenmore dryer does not heat , element has continuity
Check the thermal cut-off located on the heating housing. check for continuity on that.
Jul 03, 2009 | Kenmore 73952 Gas Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryer will not start
Your start botton wore out inside. You can change it. Please note to connect wire exactly as the old one.
Good Luck
Aug 02, 2008 | Kenmore 63942 Dryer
Kenmore 62972 ele dryer
THERE IS A SMALL RELAY THAT THAT BUTTON ACTIVATES ... THE RELAY SOUNDS LIKE IT IS BAD. BEFORE REPAIRING I WOULD HAVE A "FIXED-FEE" DIAGNOSTIC TEST DONE. USUALLY 30-50 DOLLARS. THEN THERE IS THE REPAIR COST. IS IT WORTH IT?
Apr 28, 2007 | Kenmore 62972 Electric Dryer
Kenmore 73952 Gas Dryer Logo
317 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
