Question about Kenmore 71812 / 71814 / 71819 Bottom Freezer Refrigerator
Kenmore 596-76512 fridge not cooling freezer seems to be working still
Our fridge stopped working. It is a side by side with a bottom freezer drawer. the fridge is at 58 deg and rising. The freezer is still at zero deg. I took the back cover off and I noticed the fan is not running at all. I unplugged the fridge then plugged it back in and all I could hear was the damper thing inside the refer at the top back. The compresser felt slightly warm, not overheating. All I could see was a capacitor on the Compressor and the fan itself. There was no dust collected anywhere. Should that fan be running all the time...could that be the problem? Could the capacitor be bad? They want $200 to come look and it isnt till 2 weeks out. GREAT customer service! thanks in advance.
  • Anonymous Mar 27, 2014
    freezer working fine but fridge hardly cool fridge compressor running
  • 237 Answers
If the fan above the evaporator coils in back of the cover isn't running then no cold air will be blown up to the fridge area. That's a common failure item and very easy to replace yourself. And by the way... $200 bucks and 2 weeks out is about normal these days believe it or not. It's what we would charge ya! :) At least you did the troubleshooting and saved yourself a couple hundred bucks.
Posted on Jan 15, 2007
  • Marc Wilson
    Marc Wilson Jan 15, 2007
    As a note, the fan by the compressor is the condensor fan and I too should be running if the compressor is. Your problem is likely the fan inside the freezer drawer rear cover not blowing air up so you'll have to take that back interior panel off to replace it. While there make sure there isn't a solid ice block on the coils. The coils should have a nice frost pattern but not solid ice. If for some reason you find solid ice and the evap. fan is actually running then you have a defrost cycle failure so let us know what you find.
  • 3 Answers
Tock. My bottom drawer-freezer model is the 18cu.ft. model but has had the same problem twice. The first time the technician simply removed the two-piece plastic covering, making the inside floor of the refrigerator section. This exposes the styrofoam insulation over the freezer coils, which he then also removed. The problem was that ther was an ice build-up at the 'defrost water'drain and this eventually grabs the blade of the air circulating fan. The ice is removed and all is well again, BUT, it happened again and I did the fix myself. My belief is that there is a design fault with the slope of the water drainage after defrost.
Posted on Apr 01, 2007
  • Alan Leslie Apr 01, 2007
    Add to solution #2 by Ales. Despite the circulating fan actually becoming locked in ice, when freed it continued working and NO NEW PARTS were needed! This applies to both times the ice build-up occurred.
  • Alan Leslie Jun 26, 2007
    The freeze-up of the air circulating fan has now occurred 4 times. A technician added self adhesive foam tape along each side of the exposed styrofoam divider between the fridge. and freezer section. I have also increased the backward tilt to get the defrost water to flow better. The added tape was suggested by the manufacturer. So far so good but only time will tell.
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Our ED5SHAXMD10 freezer is way too cold, and the fridge side seems too warm. The vent into the bottom drawer keeps freezing up.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 05, 2010 | Whirlpool ED5SHAXM Side by Side...
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 71812 / 71814 / 71819 Bottom Freezer Refrigerator Logo
2,134 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
