Question about Sony Ericsson K510i Cellular Phone
Can you help please?
I have been trying to charge it but it's saying battery is fullky charged, I know it isn't because I have not used it for months.
Also it won't let me enter digits 1,2,3 from the top row of numbers into the screen..other digits can be entered but they are not part of the pin code.
It did let me once get into the phone but cut me off and swtiched off about 5 seconds later.Keeps looking like it's coming on but cuts out.
    Genius:
  • 1,011 Answers
Dear,
did u tried or open the internal cassing . i think any button is permantly pressed or causing this problem. u have to open the cover again of if first time then clean its keypad and then intially charge the full battery and then check.
try to do a master reset/default factory at the end, if issue is still persisting. But save contacts and sms first.  reset can delete them
regards,
Posted on Jan 01, 2009
My laptop battery says Unknown Remaining but it's fully charged
open laptop back panel and unplug the bios battery , then with the help of any screwdriver try to short the bios pin. 100 % work
Apr 21, 2012 | Computers & Internet
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Battery lufe is rubbish
How old is the phone/battery?
Most cells use LiPo batteries, which can be very tempermental. If they are fully discharged (used until they will not power item any longer) more than a few times, they can lose the ability to hold a charge. Also, check the phone's users manual for correct battery charge times, as many Li/Po batteries will show a full charge before they are actually fully charged, particularly for the first few charges. If your battery isn't holding a charge, the easy fix is to replace it, but if the phone/battery is less than 6-12 months old, I'd ask my cell provider to replace it as defective.
Hope this helps,
r
Sep 12, 2011 | Cell Phones
I've had my acer aspire 5741z for about four
I think the problem is your battery pack..or to make sure contact a reliable and skilled computer technician handling the trouble personally is much better to make sure it will be fixed in no time..
Jul 05, 2011 | Acer Computers & Internet
Isn't starting. battery isn't getting a charge. bike starts once the battery is charged
Your battery MOST LIKELY has lost some of the battery cells, which will cause it to get a partial charge which will show it as a FULL charge when in fact it isn't getting a full charge. You should try taking it to get the battery tested and they can tell you if it needs to be replaced. I would guess they are going to replace it for you. A new battery should run around $90 for a motorcycle. Let me know if this helps you out. Jeff from fixya
Jun 11, 2011 | 2007 Hyosung GT650R TTC
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
I have the 1080P 30 FPS / 720P 60 FPS. I have had it for 6 months but am charging it for the first time. I have inserted the battery correctly. The manual says a red LED light will go on, but all I get...
Hi! This is surely a faulty battery.... Please replace the battery and you'll be good. Hope this helps and thank you for using FixYa!
Oct 05, 2010 | Cameras
We had a new battery it Razr/V3c and the phone is working but try to charged the battery and it say "unable to charged" i need to know why it not working.
hi ... i think your battery charge is gone under minimum limit ... Please try charging your mobile with another battery and try to switch on your mobile and after five min remove the battery, charge with your battery and see whether its charging or wat??
May 30, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Durabrand Portable DVD Model # PDV-705
hi sir. any rechargable battery is to be treated like that way 1 -never leave the empty battery without charging any way because if you get it uncharged for one day you loose life time 2- charge it emmideatly after use for two hours or to end charging sign 3- evry two months try to completly discharge it and re charge 4- don't leave the batt, not working for more that 4 months 5- if you want to leave for more that 3 months charge it well and comletly please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Durabrand DUR-1700 Portable DVD Player
Sony Ericsson K510i Cellular Phone Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
