Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
Cannon ixus i connection
I have installed the software from the cdrom, set the camera in its cradle, connected the usb cord to the usb port..... but! when I open CameraWindow the dialogue box tells me that"no camera was found" and since the readMe is in Japanese and the Help sections not helpful....I can't think what to do next. if you can help - cheers. Do I need to install the camera? it doesn't say so. I am using a Mac OSX
Socket may be broken
Posted on Aug 28, 2007
  • 641 Answers
Go to Canon web side and download to your computer the relevant drivers for your camera and OS (Mac OSX). It should solve your problem. Good luck!
Posted on Jul 31, 2007
Hi, I can not tranfer images from camera to computer using a usb cord. I tried 2 different cords and 4 different computers. I do not have a card reader, so please don't ask me to go purchase a card...
Emily,
We need to rule some things out. Do the USB cables you're trying to use work on other "known to be good" devices? Do not reuse any cable(s) that doesn't work, even if new. Once you have a cable that has been proven to work, try connecting the camera to the USB port on the computer again. Make sure the camera power is OFF while connecting to the computer. Only after connecting should you turn camera power ON again. You can review the whole process starting on page 147 of the manual.
If it doesn't work, it is possible that the ports you're trying to use is either 1) defective or 2) overloaded. Try connecting to a different USB port on one of the computers. If you don't have another USB port, or if it still doesn't work as expected, remove all the devices connected to the USB ports that are not needed to operate the computer. This will lower the amount of power the computer needs to supply to USB devices (some - but not all - computers will flash a message on the screen if there's too many devices connected). Reconnect the powered off camera and try again after turning back on..
If you're still having a problem, suspicion turns to the camera's USB port. Resolving a problem within the camera will likely be the most expensive fix. It took considerable restraint, but I didn't even mention the other solution ;-)
I hope this helps & good luck! Please rate my reply - thanks.
Feb 11, 2011 | Canon EOS Rebel XSi Digital Camera
Canon IXUS 330 not recognized by Windows 7
Try not to connect at front usb. Only back USB (due to lack of power in it)
Oct 15, 2017 | Canon PowerShot S330 / IXUS 330 Digital...
Windows needs to install driver software for your canon...?
try re installing the software again, or maybe its not compatible. try and update via internet
Feb 18, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Usb cdrom on the on the optiplex 760 keeps disconnecting. how can i correct this problem? Talleys.
Could be Hardware or Software problem, try below suggestions 1 at a time to pinpoint the problem.
Hardware:
  1. Restart Computer with USB CDRom not attached. Then attach.
  2. Make sure power connector to USB CDRom is firmly connected.
  3. Change to diffent power outlet for power supply of CDRom
  4. If connected to USB Hub, disconnect and connect directly to the computer.
  5. Try a different USB port on the computer
  6. Use a different USB cable (if using an extender, disconnect) Cable should be 6 foot cable or shorter.
  7. Try a different external CDRom drive to verify it is not a problem within that unit.
Software:
  1. Do windows update. Also Choose CUSTOM update (3rd option is drivers). Update all drivers available.
  2. Download most recent drivers from manufacturers website and install.
Nov 09, 2009 | Computers & Internet
Machine will not print,don't think i have the correct cords plug
first thing is to connected your power cord which is the one that goes into your wall jack.
then installing the software from the CDROM. During setup your will prompted to plug in (connect your printer) into the USB port (the cord of which looks like this in the link
http://picasaweb.google.com/lh/photo/CnP0eiofVW7qehWsT53lNw?feat=directlink
This will install your printer part.
As for the fax you need to plug in your telephone cord into its place and into the phone jack in the wall.
http://picasaweb.google.com/lh/photo/U3C-gdo9XR_fRU3Rzq6VVQ?feat=directlink
this cord can be put in either way.
the squigly chord goes into your headset.
and you are set,
helpful?, fixya? need more help ?
Mar 26, 2009 | Lexmark X4270 All-In-One InkJet Printer
Syncing camera to computer
What operating-system are you running?
On Windows XP and earlier versions of windows, there should be an icon on your desktop called "My Computer." Click on it once you've attached the camera. You'll at least see "Local Disk (C:), DVD/CD-RW drive (D:), Shared Documents, My Documents", and such. If your computer sees this USB camera, it should list it here. You can click on the camera's icon to view all your pictures.
On Windows Vista, getting to "My Computer" is a little bit trickier. I forget exaclty how, but it's not just set on the desktop like all previous Windows platforms.
Nov 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Mar 30, 2008 | Olympus FE-190 Digital Camera
Not acquiring pictures with any software
don't think it was the cable, they are a standard usb interface cable.
Had a similar problem, when I installed software for a new camera interface.
you can manually open the cannon software once the camera is hooked up to your computer. Its called "camera window" default install is start>all programs>cannon utilities>camerawindow>poweshot>camerawindow
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Re setup
ok depending on how you have installed it, normally the software/installation cd has to be installed first, so remove the printer and start again, the .inf file it is looking for is the driver file, but the cdrom should firstly set this up when installed, only then the printer can be attached. If you have to connect the printer first, then you will have to force windows to look in the cdrom drive for the files to install the driver as it may be looking in 'C' where windows is installed instead. The usb hub you have will probably be a usb1.1, but your printer will prefer usb2, so try it in other usb ports, that you haven't got the hub connected into, remove any other hardware that is connected to your usb ports at rear of pc and connect them to the hub instead, as one of the used ports may be usb2. Having said that your printer does not have to have usb2.0 to function, using the usb1.1data rate is just slower than usb2.0
Jun 12, 2007 | HP Photosmart 2575 All-In-One InkJet...
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
133 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
