Sir i want to know about distrubuted control system
No spark
The Engine and Automatic Transmission (not applicable to manual transmissions) in this vehicles drive train are fully electronically controlled by a computer called the PCM and TCM (Power Train Control Module, Transmission Control Module). When a problem like this or other drive-ability related problems occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for correct spec for your make and engine type.
Sep 10, 2012 | 1996 Dodge Avenger
Need serial number for versacheck
That problem will be hard to find unless you have access to a scan tool but most likely its 1 of the relays either fuel or auto shut down there are several fuses that also control these relays they are #13 and N- T- and W in the power distrubution box I hope this helps you
Dec 10, 2011 | G7 Productivity Systems VersaJette...
Engine surges at idle
Throttle control valve, or sencer. good luck. First check your distrubuter can and may have jump time a tic.
Mar 26, 2011 | 1989 Volvo 740
My friend to told me that her lights were deam more lightly I know that it could be the battery. or it could be the alternator
There is a voltage regulator, that regulate the amount of electrical current from your alternator to distrubute to the car, so the car will run stable even if you have your lights, radio on. from my point of understanding, it's your alternator that is causing this, and when your friend turns on her light, the voltage regulator is trying to provide power for the light bulb, but yet keep the engine working. It's kinda like a house, where you have your tv on, and lights on, and then your turn on like the vacumm and the lights dim a little bit because electrical current being distrubute.
Jan 28, 2011 | 2004 Chevrolet Cavalier
I have a 2002 Yukon Denali and I was wanted to know, how do u change the bulb in the steering wheel?
Steering Wheel Control Switch Assembly Replacement Removal Procedure
  1. Remove the steering wheel. Refer to Steering Wheel Replacement .
  2. Remove the horn switch from the steering wheel.
  3. Remove the steering wheel shroud retaining screws from the back of the steering wheel.
  4. Remove the steering wheel shroud from the steering wheel.
  5. Remove the steering wheel control switch mounting screws.
  6. Disconnect the steering wheel control switch (2) electrical connector (1).
  7. Remove the steering wheel control switch from the steering wheel.
Steering Wheel Replacement Tools Required J 1859-A Steering Wheel Puller
Removal Procedure
  1. Disable the supplemental inflatable restraint (SIR) system. Refer to Disabling the SIR System in SIR.
  2. Remove the inflator module. Refer to Inflatable Restraint Steering Wheel Module Replacement in SIR.
  3. Remove the horn switch. Refer to Horn Switch Replacement - On Vehicle .
  4. Make an alignment mark in order to note the relationship of the steering wheel to the steering shaft.
  5. Remove the steering wheel nut.
  6. Remove the steering wheel, using the J 1859-A .
Installation Procedure
Oct 04, 2010 | 1995 GMC Yukon
Sir, i have problem with missing rivers 1.
Could you please let me know the operating system installed on your Notebook.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
I need the part that controls the distrubuter and starts the car its located under the dash bolts up against the outside of the frame behind the hood release latch it common for these cars to go out when...
It controls the EFI/PGM-FI. In short the Fuel Injectors. It's a main realy under the driverside dash, under the cruise control box.. It's called a "Main Relay"
Oct 11, 2009 | 1990 Honda Accord
No fire to spare pluge
The 5.2 V8 has a distrubuter that has to get key on power and ground. After that tested or corrected to good, then the coil should be tested for key on power if it's not there that circuit needs found. Lets say its good then the distrubuter pick up the in the distrubuter can fail their $50 and most stores will have them in stock, their easy to change provided that your a good mechanic enought to be able to get the distrubutor cap and rotor on and off with out much troble
Aug 26, 2009 | 1998 Dodge Ram 1500 4WD
2010 distrubuter problems
The timing gear is made from material which will break if the gears are not meshed correctly, if the distrubiter has come loose at some time, this can chew out the timing gear and leads to all sorts of problems (ie correct timing)
Jan 26, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
