Question about Toshiba Satellite L25-S119 Notebook
Satelite L25-S1196 Hi, I recently flew overseas and forgot my adapter. I found a local IBM adapter and plugged in. The laptop powered up and worked fine. But the battery will not charge. I replaced the adapter with a toshiba adater for the laptop and also replaced the battery with a new one but the new battery will not charge. The battery indicator keeps blinking. I hope i did not damage my board.
    Genius:
  • Toshiba Master
  • 1,252 Answers
Its better if you should take it to the technician and checked by him
Posted on Nov 28, 2008
I have an a31 i recently replaced the battery it works fine but when ever i put it for charging and disconnect it when it is done the battery meter says it is still connected so i cant get my real power...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 29, 2011 | IBM ThinkPad A31 Notebook
My Toshiba Satellite L25-S121 PC Notebook does not work, problem with power
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a dry solderjoint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jan 17, 2011 | Toshiba Satellite L25-S121 Notebook
Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
Sep 06, 2010 | HP Compaq 6735s Notebook
Lap top wont turn on.
the problem is because, the power circuit is not working properly. or the battery is gone bad,, so check the power supply,, thank you,, plz rate me,,
Jun 27, 2009 | Toshiba Satellite L25-S121 Notebook
Power to Toshiba L25 s1196 laptop
make sure the output wattage and voltage of the universal matches the original, if not you can damage the PC. look on the actual inverters, they take AC wall voltage and Transform it to DC power, the specs will be listed. some universals have switches to adjust the voltage, etc.
Mar 30, 2009 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Hi, i recently flew overseas and forgot my adapter. i found a local IBM adapter and plugged in. The laptop powered up. But the battery will not charge. I replaced the battery but the new battery will not...
It's simple. Use a toshiba adapter. An IBM one may have the same pin but maybe not the exact voltage/amps. I have done this before and it messes up the battery so you cant charge it anymore.
Nov 28, 2008 | Toshiba Satellite L25-S119 Notebook
Thinkpad T43 wont get any AC power
I've run into this many times with IBM machines. The power management chip on the motherboard has failed. Unfortunately, you will have to replace the motherboard in order to fix the problem.
Aug 13, 2008 | IBM ThinkPad T43 Notebook
Toshiba Satellite L25-S119 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
