How the wiring is done in dcs from the field to HIS
Sir i want to know how exactly wiring is done in dcs ........
mean suppose we have one DP transmitter i want to get the indication of transmitter in DCS..........
  • Chester Harvards
    Chester Harvards May 11, 2010
    I am an electronic laptop Tech.
    could you tell me more details about what you want to do for the DC power or AC power..what input and output for your "transmitter"
I have a 2003 Cadillac Seville STS and the my air bag and brake light came on dashboard with a alert that said something to the effect of check rider system. Does anyone know what exactly this means.
It would have to scanned with a computer to see exactly what is wrong.It could be the sir module,passenger side airbag, front sensors, or a short in the wiring. Without codes this is as far I can go. Even with codes, sensors and wiring would have to be checked..But codes give you a direction to look.
Jun 22, 2014 | Cadillac Seville Cars & Trucks
DCS CT365SS igniter wires?
no not standard. but you can replace them if you know a good place to buy high temp wires. If not buy the upper wire harness for the range and the igniter wires will be in that.
Jan 06, 2012 | DCS Cooktops
What is the largest mb sd card the kodak dcs pro 14n will read ??
Hello!
Seems the DCS PRO/n do not handel SD cards with HC capabilitys. So the largest SD cars that there is i 4GB. Problems is to find such a card.
In reallity 2GB is possible.
I recomend You to obtain a CF card instead. I use a 16GB CF and it work like a charm.
I suppose the DCS 14/n work the same way.
Regards PeO
Sep 25, 2010 | Kodak DCS 14n Digital Camera
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Panasonic copier DP-2330
Hello sir; Check the letter size tray, seems like tray lifting motor defect.
May 27, 2009 | Panasonic WORKiO DP-2330 Copier
Fault E05-02
Hello sir; According the manu, the error you display,it means 12 volt low voltage power supply board have problem, change it.
Apr 28, 2009 | Panasonic DP-C264 Copier
Engine failing to start due to electrical problems through ECM
HELLO Rebelsfruit,
Year make & model would HAVE at help...
I would love to help you with your restoration project:
You are currently listed under Volvo S60 ...failure to
Disclose the size & NATURE of your "Shredded" wires
is a LOGISICAL issue on your end (just make sure
the gage, type size and insulation of every "PATCH"
is EXACTLY correct... and if the wires are "twisted" or
braided... That "TWIST" must be duplicated exactly.
(ditto... color (I would recommend a salvage yard
or NEW harness before ever recommending a
ROOKIE field engineering solution)).
Solder and HEAT-SHRINK tubing are the correct way
to put in all your splices... (patching).
The fact that ALL your lights are on is an EXCELLENT
indication... Your system is designed to do that as
part of your INITIALIZATION...
(all the wiring to the dash & the indicators are ALL good
(remove power)).
In order to get DEEPLY into your sophisticated ELECTRONIICS
You MUST observe ELECTRO-STATIC DISCHARGE (ESD) precautions.
Cheap $6 wristband (wear it...!!)
https://www.amazon.com/Rosewill-Anti-Static-Components-RTK-002-Yellow/dp/B004N8ZQKY/ref=sr_1_2_a_it?ie=UTF8&qid=1516475232&sr=8-2&keywords=rosewill+wrist+strap
FREE drawings at
BBB Industries Premium Alternators Starters Power Steering Products
(again... cannot be stressed enough)
ESSENTIALLY
That means you do nothing that would generate
ANY SPARKS (you might not even feel) around or near
DELICATE SEMICONDUCTORS you care about...
While vehicular ECU/ECM prices are astoundingly
low... (popular) That only indicates to me that there
is a whole lot of INCOMPTENCE out there...
ASO IMPERATIVE... cheap/cheesy volt meters can
damage SEMICONDUCTOR just as surely as a bullet...
Buy a tone TRACER and learn how to use it...
((trace only ISOLATED WIRES ))...
Only restore power after every engine WIRE
HAS been traced from end to end...!!
Carnac the Magnificent
Jan 19, 2018 | 2004 Volvo S60
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Panasonic dp-3010 MAC driver download
you can go here to get you mac driver
http://panasonic.co.jp/pcc/products/en/mfp/download/index.html#DP-3010
but you need to have a post script key installed in your machine.
Jul 07, 2008 | Panasonic Workio DP-3010 Printer
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
