Question about HP Inkjet 1200dn Printer
Inkjet 1200wn won't start
When I push the power button it usually takes a little time, the printer gives some noise sounding like some machinery inside the printer is moving. Then after a short time a blue light next to the power button switches on and the printer is connected to the wireless network and is ready to print. This is the normal procedure. However, sometimes nothing happens. Then I pull the plug out try all over again. Usually, it works the second time and sometimes not until the third time. It has been like this for a couple of years.
But now suddenly, nothing happens, no sound from the printer and no blue light and no connection to the printer.
Jens Arleth
  • 189 Answers
Kindly check the power supply to your printer, if you have a voltmeter test it for electricity if there is an eletricity, then it's the printer that has a problem have it check by a technician, if there is none electricity from the power supply then change your power supply adaptor.
Posted on Nov 28, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description, this is a failed power supply adapter. Should your particular version/model uses and external PSU adapter similar to the one shown below, then it would require either servicing or replacement.
Incidentally, one is available from eBay.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • HP Master
  • 19,396 Answers
REMOVE BOTH CARTRIDGE, THEN UNPLUG MACHINE FOR TEN MINUTES, PLUG BACK AND REINSTALL THE CARTRIDGES.
  • Ginko
    Ginko Nov 28, 2008
    If you get no power at all , then , as already suggested the problem is with power supply.
    If this occurrence happens from time to time, then it is often because of a bad power connection or a bad power lead.
    Check power connector on the printer, check also the power cord connection into power adapter, if you still get the problem, replace the power adapter.
    Check the cable connections first. If the power cord is defective, get a replacement at any local store. If the adapter is faulty, replace it: AC adapter for HP Business Inkjet 1200 Printer ...
    If the printer power socket (theone on the printer) had a bad soldering, and lose power contact, take the printer to a local repair shop.
HP 1315 printer won't turn on
I have an HP printer too, but it's HP 2050. When i plug it in it usually makes a noise and then the power button blinks. To turn it on requires me to hold the power button down for a few seconds until the power button light stays on. If you haven't tried yet, try pushing down and hold and see if it turns on. Hope this helps :)
Apr 20, 2014 | HP Photosmart 8450 InkJet Printer
After the sound stops and the light goes off, I stop pressing the button, but then the sound starts up again. The machine seals and vacuums properly, but I worried that it makes noise again. thank s
I guess your talking about a foodsaver. The noise is from the vacuum pump and is usually a little loud. You shouldn't need to keep your button pushed. Is it working when you just hit the vac/seal button and release? If your holding it the whole time, it may be starting another cycle.
Dec 12, 2013 | Heating & Cooling
HP deskjet 3054 broken power button
Hp's usually have a micro switch underneath the power button. You probably just broke a support arm or type device. You might be able to super glue the piece back together and make it work. In my experience, this usually works about 40 percent of the time. Usually by pushing to ******* the switch to break the plastic you could have possibly damaged the small micro switch. My best suggestion is take it apart and try the super glue fix first. Good Luck!!
Jun 13, 2012 | HP Deskjet F2210 InkJet Printer
The printer will not start when you push the start button. It is a new printer
Most likely, this issue might be caused by Start button being stuck. If you can't turn the product ON by pushing the Start button, double check if the Start button is somehow stuck, and also make sure that the unit is firmly plugged in to the wall outlet. If that doesn't resolve the issue, try a different outlet because you might be experiencing power outage on the outlet where it's plugged in. If that won't resolve it, I'm afraid the unit has to be serviced.
Apr 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Ink absorber is full - How can I repair it
You reset the ink absorber like that:
1.printer is offline
2.push resume button is red and in the same time push power button
3.do no let resume (red) button,and push the resume button 2 times
4.wait to appears numer zero to the screen
5.them push four times to resume button
6.close the printer and start up
If i have been useful please give me a vote :).Thanks
Apr 11, 2011 | Canon PIXMA MP190 All-In-One InkJet...
How to reset code e27 by myself?
Mar 30, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a problem my printer show 5b00 but a cant find aut what to do? prisma pm 170 can you help me thank you inger
Mar 29, 2011 | Canon PIXMA MP170 All-In-One InkJet...
I am receiving a message: ink absorber is almost full. Contact service center.
If a have been usefut please give me a vote :).Thanks
Mar 14, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP130 Error message:- cartridge jammed service error 5100 How do I rectify this problem?
I HAVE THE SAME PROBLEM- CARTRIDGE JAMMED-. :o( I HATE PIXMA MP130, cant seen to make it work, last resort: throw it against the wall! GGRRRR! if you find a solution please post.
May 13, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP Inkjet 1200dn Printer Logo
Seeker5211
Seeker5211
