Question about Toshiba Satellite A55-S106 Notebook
Modem I think I need to replace the modem hardware. I had the telephone line connected to my computer during a storm and I think I fried the modem, or the jack at least. Ever since then I cannot use my dialup modem. Do you have a step by step pictorial or something I can follow to open this thing up and replace the modem? Thank you
  • 93 Answers
First, you better the driver of the modem was well installed in Device Manage.If not, re-install the driver from Toshiba site again.
second, check/replace the phone line to make sure not the cable's problem.
And if it still same, you check Toshiba web to find what modem card look like for your laptop model and how much for cost(not cheap), and you can open a small cover from the bottom of laptop, and will see a small PCB board with a wire attached(Must look like what you see from Toshiba site, make sure it is not memory chip), then carefully unplug from motherboard and wire and replaced new one if you buy. BUT I don't think it is DIY.
The cheap way is buy a PCMCIA card modem and plug in the PCMCIA slot, which every one can do it.
Good luck.
Posted on Dec 02, 2008
Modem connection
From Page 68 of the CF19 Reference Manual:
Modem 68
<only for model with internal modem>
CAUTION
?? Do not use the PBX internal phone lines installed in company offices. Doing so may lead to a fire or electric shock.
?? You cannot connect the modem to the following lines.
• Interphone
• Intercoms
• ISDN
?? Be sure to connect the telephone cable into the modem port, not into the LAN port.
?? Use a surge protector since the modem may be damaged by a sudden high voltage surge that may occur in the event
of a lightning strike.
1 Open the cover and connect the telephone jack (A) to the computer
by using the telephone cable (included) (B).
?? Hold the cable so that the shape of the connector (C) matches the port, and
insert fully until it clicks.
2 Click [start] - [Control Panel] - [Printers and Other Hardware] -
[Phone and Modem Options] and change the settings as necessary.
NOTE
?? Do not enter standby or hibernation during communications.
?? To remove the cable, press and hold the lever and pull out.
This is everything about the modem.
Good Luck
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Sep 12, 2013 | Panasonic Toughbook 19 Notebook -...
DSU 6424 connection
Unfortunately if the problem started after a lightning storm the modem is almost certainly fried. I used to work at the UK's largest IT support call centre, we used to check the weather reports every morning because if there had been a lightning storm anywhere in the country we'd get a slew of calls from that region from people who could no longer connect to the web. Phone-lines collect a large static charge during a storm and are unprotected. I'd strongly suggest you contact the supplier regarding replacement.
Aug 21, 2007 | Datacom CMS 6424 (cms6424cs-dual) Modem
I have a Dell inspiron 537 sesktop pc and the lan adapter is not recognizing the ethernet lan connection. I reinstalled the drivers etc but it still show " not connected ". Is there anyway to...
To connect to the Internet, certain hardware and services are needed, which are listed below. Without any one of these items, connection to the Internet is not possible.
  • Broadband Internet Service (also known as Internet Service Providers or ISP) - Telephone companies (also known as DSL, which uses a telephone line) and cable TV companies usually offer Internet service.
  • Broadband Modem - Normally, a broadband modem can be rented or purchased from the ISP.
  • Computer with a Network Adapter - This is usually a device located inside the computer.
  • Broadband Router - A router is used to connect all of your computers to the network (but is not needed for a single computer). The router also provides a way to connect to the Internet through the Broadband Modem.
Oct 12, 2011 | Dell Inspiron 537 (DDCWQA1_7) PC Desktop
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
Cannot receive phone calls on a dsl setup
There must be DSL Spliter inbetween telephone line & Wi-fi modem. Please check whether you have connected telephone instrument line with that Spliter or not. According to me, Telephone instrument should connect to telephone line option on DSL Splitter to use same telephone line as internet as well Telephone.
Mar 03, 2010 | Computers & Internet
D-link DSL-320T Dead
yes it can be a problem... thats why it is advisable to buy telephone line surge protectors or disconnect the telephone cable connecting to DSL router.
Aug 05, 2009 | Computers & Internet
Fax modem does not transmit. We recently had a bad storm and it was connect to a powerline phone jack. The phone jack was fried during the storm and i think the modem was too. I think the modem needs...
No...you nedd the proper HP Modem, and unless this is a relatively high end (several hundred dollar) machine -because you have not listed the model, then you might as well use it for a really big paper weight now, and buy another one, because repair will be far more, than cost of machine -I recommend buying a good surge supressor at the same time too (and i'm not talking about a power bar)
Jul 31, 2009 | HP Office Equipment & Supplies
I have a Dell Dimension DV051 tells me your modem appears to be in use by another program please quit all programs & try again. I tried reinstalling the modem but that did not work. There was a bad...
But you telephone line might be connected to ur modem??
chk for any burnt mark on modem or run modem diag that is an tool send by dell to chk ur modem
Jul 02, 2009 | Dell Dimension 3100 PC Desktop
Was able to get connected to the internet twice to day when i came back in to get on the computer it couldnt connect to the internet said no dial tone. this is a new dell computer with an external modem...
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
Apr 17, 2009 | Dell Inspiron 530 Desktop Computer
Printer will not turn on
the UPS is unplugged from the power outlet but it is still connected to the modem
it is a lightning storm - and computer equipments & peripherals can only withstand very little amount of electricity
check your warranty status (warranty starts from the date of purchase) then call the vendor
Dec 20, 2007 | Epson RX620 All-In-One InkJet Photo...
Computers & Internet Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
