Question about Dishwashers
Good morning! I have a hotpoint built in electronic paneled dishwasher that fills up w/ water when off. Water slowly seeps in from bottom and I have to syphon it out (yuck). Electronic panel beeps, that there is too much water. can you help me?
  • yaffefam Nov 28, 2008
    It works!!!!!!! Thank you so much!!!! four stars
    Sergeant:
    Champion:
  • 311 Answers
The water inlet valve is most likely bad and needs to be replaced, especially if it fills up over a long period of time. Easy to replace.
Posted on Nov 28, 2008
  • JEFF SIEGEL Nov 28, 2008
    Glad to help and thank you!
Kenmore dishwasher filling with water when not in use
The water inlet valve is defective.Turn off the power and close the valve to the water supply line Remove the kick panel on the front of the dishwasher remove the supply line, the clamp to the supply hose, the electrical connectors, ans the screws holding the valve. Reverse process to reinstall. Turn water on and check for leaks Turn on power and you are good to go
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
No pressurized water spray
internal pump failure....check that it is not blocked ...the water supply hose only fills tank then the pump pust pressurised water to the spinning arms.
Jul 20, 2010 | Hotpoint 24 in. HDA900X Built-in...
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My ice maker is turned off, but water slowly seeps into the tray
Try turnig off the fridge and let it defrost,keep the doors open and put pans of hot water in the freezer,wait 6 to 12 hrs.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Hotpoint HDA1100Z04WH
Is this syphoning, if so, raise the hose higher.
Jun 03, 2008 | Hotpoint 24 in. HDA1000Z Built-in...
Sears Kenmore dishwasher drains and then fills back up.
you have a nearly-clogged u-tube near the connection to your house drain piping. clear the clog out.
May 31, 2007 | GE 24 in. GSD4020Z Built-in Dishwasher
NO WATER
if an older machine, suspect the wiring loom where it turns at the bottom of the door. take outer door panel off and carefully examine the loom and pull each wire to make sure it is intact
Mar 24, 2007 | Hotpoint 24 in. HDA1000Z Built-in...
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
