Back to:
Tags:
Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo
Dvd won't read and makes a clicking noise (by 2 users)
posted by thnkfl9 on Jan 14, 2007
dvd won't read and makes a clicking noise when i push play
the problem started with dvd skipping a lot-
now it won't play at all- thank you for any suggestions
Comment by thnkfl9, posted on Jan 17, 2007
Hi nfandres-
Thank you for your response-
Can i access the lens and lens assembly without taking anything apart?
do you recommend a certain type/brand of dvd lens cleaner?
do i blast some pressurized air duster in there?
thanks- i've never fixed any electronic in my life
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by post man, posted on Mar 10, 2008
i have the same problem as thnkfl9, it wpuld not read the dvd"s and the clicking sound Also when i try one of those dvd cleaning disk the tv would try to read that disk and would say this type of disk cannot be played. help me please i have had this tv for about two years.
Best Solution
posted on Jan 16, 2007
Helpful (85)
nfandres
Rank:Guru Guru
Rating: 88%, 225 votes
clean the lens with a clean, dry and soft cotton swab. use also microduster to remove accumulated dust inside the lens assembly.
Comment by nfandres, posted on Jan 21, 2007
yes you can access it without taking any part, just the cover of the vcr/dvd unit. i've never use any type or brand of dvd lens cleaner, just clean, dry and soft cotton swab and aircompress duster usually use for computers. yes u can blast some pressurized air duster in there. if the problem is still the same after these precedures, maybe its about time to send it to a shop for further analysis. maybe the optical lens assembly needs to be replaced. good luck!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dvd won't read and makes a clicking noise:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
We just had a very short sudden thunderstorm and our...
I have somewhat similar problem to others. I only use this...
i cleaned my dvd player and now it acts like the disk is...
windows media player shows problem code C00D1199 when i...
ve a pansonic Tv PV-DF2704 tv turn on and then click right...
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
